Introdução
Has the lens on your Nikon Coolpix S230 ceased to function properly due to scratches, exposure to water, or other damage? This guide will walk you through all the steps to access and remove the damaged lens assembly so that it can be replaced with a working assembly.
O que você precisa
Using a Phillips #000 screwdriver, remove the four 2-mm screws from the side of the camera.
Remove the two 3-mm screws from the other side of the camera.
Finally, remove the three 4-mm screws from the bottom of the camera.
Ferramenta utilizada nesse passo:Tweezers$4.99
Carefully lift the LCD screen to reveal two orange ribbons connecting the screen to the camera.
Use tweezers to carefully lift the blue retaining flap holding down the orange ribbon cable. (Flap can be seen open in the second photo)
Slowly wiggle the ribbon cable back and forth while pulling away from the zero insertion force (ZIF) connector to disconnect the cable.
Lift the button circuit board by gently popping it out of its connector.
Using a Phillips #000 screwdriver, remove the four 4-mm screws from the metal place.
Remove the solder using a soldering iron by following the instructions in this guide.
