Ir para o conteúdo principal
Nikon Coolpix S220 Accessing the Motherboard
O que você precisa
  1. Nikon Coolpix S220 Accessing the Motherboard, Outer Cover: passo 1, imagem 1 %32
    • Remove the two 2.8 mm screws on the left side of the camera.
  2. Nikon Coolpix S220 Accessing the Motherboard: passo 2, imagem 1 %32
    • Remove the four 2.8 mm screws on the right side of the camera.
  3. Nikon Coolpix S220 Accessing the Motherboard: passo 3, imagem 1 %32
    • Remove the three 4.1 mm screws on the bottom of the camera.
  4. Nikon Coolpix S220 Accessing the Motherboard: passo 4, imagem 1 %32
    • Gently lift the rear cover from the camera.
  5. Nikon Coolpix S220 Accessing the Motherboard, LCD: passo 5, imagem 1 %32
    • Gently lift the screen out of its place.
    • You will need to hold the screen slightly above the camera because it will still be attached to the camera by an orange ribbon cable.
  6. Nikon Coolpix S220 Accessing the Motherboard: passo 6, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use the tweezers to lift the ZIF connector which is holding the ribbon cables that connect the LCD screen to the motherboard.
  7. Nikon Coolpix S220 Accessing the Motherboard: passo 7, imagem 1 %32
    • Slowly pull the screen from the camera.
  8. Nikon Coolpix S220 Accessing the Motherboard, Motherboard: passo 8, imagem 1 %32
    • Remove the four 3.8 mm screws located near the bottom right and top left of the LCD base plate.
  9. Nikon Coolpix S220 Accessing the Motherboard: passo 9, imagem 1 %32
    • Lift up silver LCD base plate
  10. Nikon Coolpix S220 Accessing the Motherboard: passo 10, imagem 1 %32 Nikon Coolpix S220 Accessing the Motherboard: passo 10, imagem 2 %32
    Comprar
    • Using tweezers, lift up the retaining flap on the ZIF connector securing the button panel ribbon cable.
    • Slide the button panel ribbon cable out of its socket on the motherboard.
Conclusão
Shauna
Membro desde: 04/05/11
798 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 12-32, Maness Spring 2011 Membro de Cal Poly, Team 12-32, Maness Spring 2011
CPSU-MANESS-S11S12G32
Membros da 4
Autoria de 10 guias
Um comentário
It would be nice to have a guide for replacing the flash capacitor.
danwat1234 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 5,654
