Ir para o conteúdo principal
Nikon Coolpix L820 Settings Buttons Replacement
O que você precisa
    1. Nikon Coolpix L820 Settings Buttons Replacement, Settings Buttons: passo 1, imagem 1 %32 Nikon Coolpix L820 Settings Buttons Replacement, Settings Buttons: passo 1, imagem 2 %32 Nikon Coolpix L820 Settings Buttons Replacement, Settings Buttons: passo 1, imagem 3 %32
      • Remove the battery before beginning.
      • Use a Phillips #0 screwdriver to remove the screws on the front casing. There are 10 screws around the casing. 3 are located on the left side of the camera, 6 are located on the bottom near the product label, and 1 is located on the right side of the camera.
      Pergunte ao FixBot
      Comentar
    2. Nikon Coolpix L820 Settings Buttons Replacement: passo 2, imagem 1 %32 Nikon Coolpix L820 Settings Buttons Replacement: passo 2, imagem 2 %32
      • Next, remove the screw held on top of the camera above the Nikon logo.
      • Moving to the bottom of the camera, open the empty battery slot, and locate the 4 screws in the compartment. Begin removing the 4 screws located within.
      Pergunte ao FixBot
      Comentar
    3. Nikon Coolpix L820 Settings Buttons Replacement: passo 3, imagem 1 %32 Nikon Coolpix L820 Settings Buttons Replacement: passo 3, imagem 2 %32 Nikon Coolpix L820 Settings Buttons Replacement: passo 3, imagem 3 %32
      • Using the spudger, begin prying the case from the device, carefully separating the rear housing from the camera assembly. Once the rear housing is separated, the camera's physical buttons will be accessible for replacement.
      • Be sure to only apply pressure to the casing panels, not internal electronics. Doing so can damage the internal components of the camera.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Marc
Membro desde: 03/23/15
430 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 1-4, Miles Spring 2015 Membro de UMass Dartmouth, Team 1-4, Miles Spring 2015
UMASSD-MILES-S15S1G4
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 34
Ao todo: 1,741
