Ir para o conteúdo principal
Nikon Coolpix L32 LCD Replacement
O que você precisa
    1. Nikon Coolpix L32 LCD Replacement, Front Panel: passo 1, imagem 1 %32 Nikon Coolpix L32 LCD Replacement, Front Panel: passo 1, imagem 2 %32 Nikon Coolpix L32 LCD Replacement, Front Panel: passo 1, imagem 3 %32
      • Remove the six(3.93mm screws) on the outside of the camera using a Phillips 00 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Nikon Coolpix L32 LCD Replacement: passo 2, imagem 1 %32
      • Open the battery compartment door and pull the black back face apart from the front red face.
      Pergunte ao FixBot
      Comentar
    1. Nikon Coolpix L32 LCD Replacement, LCD: passo 3, imagem 1 %32
      • Using the spudger, gently pull the LCD screen from the tray holding it.
      • Do not pull the LCD screen far from the camera because there is a ribbon cable connected to it.
      Pergunte ao FixBot
      Comentar
    2. Nikon Coolpix L32 LCD Replacement: passo 4, imagem 1 %32
      • Use the spudger to lift up the small white retaining flap on the motherboard that is connected to the LCD screen's ribbon cable.
      Pergunte ao FixBot
      Comentar
    3. Nikon Coolpix L32 LCD Replacement: passo 5, imagem 1 %32
      • With the small retaining white flap up, remove the LCD screen ribbon cable from the motherboard by sliding it out.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team 2-4, Blackwell Fall 2016 Membro de USF Tampa, Team 2-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G4
4 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 31
Ao todo: 1,320
