Ir para o conteúdo principal
Nikon Coolpix A900 Monitor Replacement
O que você precisa
    1. Nikon Coolpix A900 Monitor Replacement, Battery: passo 1, imagem 1 %32
      • Orient the camera so that it is upside down, with the lens facing towards you.
      Pergunte ao FixBot
      Comentar
    2. Nikon Coolpix A900 Monitor Replacement: passo 2, imagem 1 %32 Nikon Coolpix A900 Monitor Replacement: passo 2, imagem 2 %32
      • Slide the battery door lock left to unlock it.
      • The battery door will automatically open.
      Pergunte ao FixBot
      Comentar
    3. Nikon Coolpix A900 Monitor Replacement: passo 3, imagem 1 %32 Nikon Coolpix A900 Monitor Replacement: passo 3, imagem 2 %32
      • Slide the yellow tab up to release the battery.
      • To re-insert a battery, slide the battery back in until the yellow tab locks it in place.
      • There is a diagram on the opposite side of the battery compartment to help you orient the battery correctly.
      Pergunte ao FixBot
      Comentar
    1. Nikon Coolpix A900 Monitor Replacement, Rear Case: passo 4, imagem 1 %32 Nikon Coolpix A900 Monitor Replacement, Rear Case: passo 4, imagem 2 %32 Nikon Coolpix A900 Monitor Replacement, Rear Case: passo 4, imagem 3 %32
      • Orient the camera upside down, with the lens facing away from you.
      • Remove the two 3mm Phillips #00 screws from the right.
      • Remove the two 3.4mm Phillips #00 screws from the left.
      Pergunte ao FixBot
      Comentar
    2. Nikon Coolpix A900 Monitor Replacement: passo 5, imagem 1 %32 Nikon Coolpix A900 Monitor Replacement: passo 5, imagem 2 %32 Nikon Coolpix A900 Monitor Replacement: passo 5, imagem 3 %32
      • Turn the camera on its side, with the lens facing away from you.
      • Remove the 3.4mm Phillips #00 screw. Repeat this for the opposite side of the camera.
      Pergunte ao FixBot
      Comentar
    3. Nikon Coolpix A900 Monitor Replacement: passo 6, imagem 1 %32 Nikon Coolpix A900 Monitor Replacement: passo 6, imagem 2 %32 Nikon Coolpix A900 Monitor Replacement: passo 6, imagem 3 %32
      • Place the camera upright with the lens facing away from you.
      • Move the monitor down, and remove two 4.4 mm screws.
      Pergunte ao FixBot
      Comentar
    4. Nikon Coolpix A900 Monitor Replacement: passo 7, imagem 1 %32 Nikon Coolpix A900 Monitor Replacement: passo 7, imagem 2 %32
      • Remove the two black 2.5 mm screws from the monitor bracket.
      Pergunte ao FixBot
      Comentar
    5. Nikon Coolpix A900 Monitor Replacement: passo 8, imagem 1 %32 Nikon Coolpix A900 Monitor Replacement: passo 8, imagem 2 %32
      • Return the monitor to the closed position.
      • Gently open the rear case.
      • You may need opening tools to help separate the rear case.
      • Be careful when opening the rear case to not damage the ribbon connectors.
      Pergunte ao FixBot
      Comentar
    6. Nikon Coolpix A900 Monitor Replacement: passo 9, imagem 1 %32 Nikon Coolpix A900 Monitor Replacement: passo 9, imagem 2 %32 Nikon Coolpix A900 Monitor Replacement: passo 9, imagem 3 %32
      • Place the camera lens down, while supporting the rear case.
      • Unlock the two ribbons by using your finger to lift the plastic hinge on the ribbon connector.
      • With the ribbons disconnected, you can now remove the rear case.
      Pergunte ao FixBot
      Comentar
    1. Nikon Coolpix A900 Monitor Replacement, Monitor: passo 10, imagem 1 %32 Nikon Coolpix A900 Monitor Replacement, Monitor: passo 10, imagem 2 %32 Nikon Coolpix A900 Monitor Replacement, Monitor: passo 10, imagem 3 %32
      • Set the rear case screen down.
      • Remove the two 2.5 mm black Phillips #00 screws.
      Pergunte ao FixBot
      Comentar
    2. Nikon Coolpix A900 Monitor Replacement: passo 11, imagem 1 %32 Nikon Coolpix A900 Monitor Replacement: passo 11, imagem 2 %32
      • Separate the rear case from the monitor assembly.
      • Make sure that the ribbon cable does not snag on the rear case when removing it.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
4Comentários do guia
Where did you get a new monitor for your camera?
photower - Responder Compartilhar
Bonjour superbe étape par étape ou puis je trouver l’écran LCD du NIKON A900 je ne le trouve pas ! merci de votre retour !
et un grand merci à des personnes comme vous qui nous aide nous pauvre novice !!!
Laurent Farrugia - Responder Compartilhar
This is excellent but where would you get a new 3” monitor?
Panders McMulluon - Responder Compartilhar
Have you tried AliExpress or Ebay?
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 66
Ao todo: 2,120
