Ir para o conteúdo principal
Nikon Coolpix 7900 Front Cover Replacement
O que você precisa
    1. Nikon Coolpix 7900 Front Cover Replacement, Back Cover: passo 1, imagem 1 %32
      • Remove the four 3.0mm screws on the bottom of the camera.
      Pergunte ao FixBot
      Comentar
    2. Nikon Coolpix 7900 Front Cover Replacement: passo 2, imagem 1 %32
      • Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
      Pergunte ao FixBot
      Comentar
    3. Nikon Coolpix 7900 Front Cover Replacement: passo 3, imagem 1 %32
      • Remove the two 3.0mm screws on the right side of the camera.
      Pergunte ao FixBot
      Comentar
    4. Nikon Coolpix 7900 Front Cover Replacement: passo 4, imagem 1 %32
      • Carefully open the back cover. Take care as there are connectors still attached.
      Pergunte ao FixBot
      Comentar
    5. Nikon Coolpix 7900 Front Cover Replacement: passo 5, imagem 1 %32
      • Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
      Pergunte ao FixBot
      Comentar
    6. Nikon Coolpix 7900 Front Cover Replacement: passo 6, imagem 1 %32
      • Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
      • The back cover will be disconnected from the camera
      Pergunte ao FixBot
      Comentar
    1. Nikon Coolpix 7900 Front Cover Replacement, Front Cover: passo 7, imagem 1 %32
      • Be careful of metallic parts which are loose and will fall out.
      • Remove the two 2.5mm screws on the bottom of the left side, after having removed the back cover.
      Pergunte ao FixBot
      Comentar
    2. Nikon Coolpix 7900 Front Cover Replacement: passo 8, imagem 1 %32
      Pergunte ao FixBot
      Comentar
    3. Nikon Coolpix 7900 Front Cover Replacement: passo 9, imagem 1 %32
      • Remove front cover.
      Pergunte ao FixBot
      Comentar
Conclusão
Kaky Payne
Membro desde: 04/17/12
121 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 12-38, Regan Spring 2012 Membro de Cal Poly, Team 12-38, Regan Spring 2012
CPSU-REGAN-S12S12G38
4 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 32
Ao todo: 1,890
