Ir para o conteúdo principal
Nikon Coolpix 3500 Lens Replacement
O que você precisa
    1. Nikon Coolpix 3500 Lens Replacement, Battery: passo 1, imagem 1 %32
      • Unlatch the battery cover and slide the cover out. Place cover to the side, it will not be needed for the next few steps.
      • Remove the battery.
      • Remove the battery cover without using excessive force. Keep in mind this cover is fragile.
      Pergunte ao FixBot
      Comentar
    1. Nikon Coolpix 3500 Lens Replacement, Front Cover: passo 2, imagem 1 %32
      • Remove the two 4.5 mm screws that sit next to the battery slot.
      • Remove the 3 mm screw that sits below the CF card slot.
      • Remove the 4.5 mm screw that sits above the digital I/O cover.
      Pergunte ao FixBot
      Comentar
    2. Nikon Coolpix 3500 Lens Replacement: passo 3, imagem 1 %32
      • Remove the two 4.5 mm screws that sit inside the battery slot.
      Pergunte ao FixBot
      Comentar
    3. Nikon Coolpix 3500 Lens Replacement: passo 4, imagem 1 %32
      • Remove the two 5 mm screws that sit near the camera strap eyelet.
      • Remove the camera strap eyelet.
      Pergunte ao FixBot
      Comentar
    4. Nikon Coolpix 3500 Lens Replacement: passo 5, imagem 1 %32
      • Remove the 5 mm screw and cap that were underneath the camera strap eyelet.
      Pergunte ao FixBot
      Comentar
    5. Nikon Coolpix 3500 Lens Replacement: passo 6, imagem 1 %32 Nikon Coolpix 3500 Lens Replacement: passo 6, imagem 2 %32
      • Remove the five 3.5 mm screws that sit at the bottom of the camera.
      • Remove the grey plastic piece, which the five screws held in place, by gently detaching the front cover.
      • Do not apply too much force; two wires still connect the front cover to the motherboard.
      Pergunte ao FixBot
      Comentar
    6. Nikon Coolpix 3500 Lens Replacement: passo 7, imagem 1 %32 Nikon Coolpix 3500 Lens Replacement: passo 7, imagem 2 %32
      • Using a spudger, detach the white-capped wire.
      • Using a spudger, detach the orange-capped wire and set the front cover aside.
      Pergunte ao FixBot
      Comentar
    1. Nikon Coolpix 3500 Lens Replacement, Lens: passo 8, imagem 1 %32
      • Disconnect the grey-capped wire from the motherboard.
      • Disconnect the blue wire attached to the green chip from the center of the motherboard.
      Pergunte ao FixBot
      Comentar
    2. Nikon Coolpix 3500 Lens Replacement: passo 9, imagem 1 %32 Nikon Coolpix 3500 Lens Replacement: passo 9, imagem 2 %32
      • Remove the 3.5 mm screw from the motherboard next to the rotating lens.
      • Invert the motherboard and lens toward the orange and blue wires still connecting the motherboard to the LED screen.
      Pergunte ao FixBot
      Comentar
    3. Nikon Coolpix 3500 Lens Replacement: passo 10, imagem 1 %32 Nikon Coolpix 3500 Lens Replacement: passo 10, imagem 2 %32
      • Disconnect the blue wire connecting the motherboard to the LED screen.
      • Disconnect the orange wire using a spudger while pushing out horizontally.
      • Disconnect the red capped wire from the motherboard.
      • Lift the motherboard and lens (still connected) out of the back case.
      Pergunte ao FixBot
      Comentar
    4. Nikon Coolpix 3500 Lens Replacement: passo 11, imagem 1 %32
      • Lift up on the black covering and remove the orange wire connecting the lens to the motherboard.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
Cal Poly, Team 30-38, Garner Spring 2010 Membro de Cal Poly, Team 30-38, Garner Spring 2010
CPSU-GARNER-S10S30G38
5 Membros
Autoria de 11 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 35
Ao todo: 3,520
