Introdução
If your camera isn't taking photos properly, and you need to replace the lens assembly, follow this guide to remove the current assembly.
O que você precisa
Remove the three 3x3mm screws that attach the front casing to the bottom.
Pry up the ribbon connector that connects the ribbon cable to the lens assembly.
