Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Nikon COOLPIX P2 WiFi Card Replacement
O que você precisa
  1. Nikon COOLPIX P2 WiFi Card Replacement, Case: passo 1, imagem 1 %32
    • Remove the screw located near the speaker port using a Phillips 00 screwdriver.
  2. Nikon COOLPIX P2 WiFi Card Replacement: passo 2, imagem 1 %32
    • Turn camera upside down so that the battery compartment is facing you.
    • Remove all four screws from the bottom of the camera with a Phillips 00 screwdriver.
  3. Nikon COOLPIX P2 WiFi Card Replacement: passo 3, imagem 1 %32
    • Rotate the camera to the opposite side where the A/V outlet is located.
    • Unscrew and remove all four screws with a Phillips 00 screwdriver.
  4. Nikon COOLPIX P2 WiFi Card Replacement: passo 4, imagem 1 %32
    • Turn the camera so that the Wi-Fi adapter is facing you.
  5. Nikon COOLPIX P2 WiFi Card Replacement: passo 5, imagem 1 %32 Nikon COOLPIX P2 WiFi Card Replacement: passo 5, imagem 2 %32 Nikon COOLPIX P2 WiFi Card Replacement: passo 5, imagem 3 %32
    • Using a plastic opening tool, pry the front casing of the camera.
    • Continue this motion all around the front casing of the camera.
    • Gently pull apart the front casing from the rest of the camera.
  6. Nikon COOLPIX P2 WiFi Card Replacement: passo 6, imagem 1 %32
    • Using the plastic opening tool pry the back casing of the camera.
  7. Nikon COOLPIX P2 WiFi Card Replacement: passo 7, imagem 1 %32
    • Orange ribbon is fragile
    • Carefully pull apart the back casing of the camera from the front of the camera without tearing the orange ribbon.
  8. Nikon COOLPIX P2 WiFi Card Replacement: passo 8, imagem 1 %32 Nikon COOLPIX P2 WiFi Card Replacement: passo 8, imagem 2 %32
    • Pull down the on the black latch to carefully separate the orange ribbon from the motherboard.
    • Pull apart the orange ribbon and front casing from the rest of the camera.
  9. Nikon COOLPIX P2 WiFi Card Replacement, LCD Screen: passo 9, imagem 1 %32 Nikon COOLPIX P2 WiFi Card Replacement, LCD Screen: passo 9, imagem 2 %32
    • Use plastic opening tool to carefully pry the LCD Screen from the camera.
  10. Nikon COOLPIX P2 WiFi Card Replacement: passo 10, imagem 1 %32 Nikon COOLPIX P2 WiFi Card Replacement: passo 10, imagem 2 %32
    • Gently pull the ribbon cable down to release the latch, then pull up to remove it from the motherboard.
  11. Nikon COOLPIX P2 WiFi Card Replacement: passo 11, imagem 1 %32
  12. Nikon COOLPIX P2 WiFi Card Replacement, WiFi Card: passo 12, imagem 1 %32
    • Continue by removing two screws from the back of the camera body.
  13. Nikon COOLPIX P2 WiFi Card Replacement: passo 13, imagem 1 %32
    • Remove the screw connecting the wifi card cover to the front of the camera.
  14. Nikon COOLPIX P2 WiFi Card Replacement: passo 14, imagem 1 %32
    • Remove the final screw connecting the Wifi card cover to the case.
  15. Nikon COOLPIX P2 WiFi Card Replacement: passo 15, imagem 1 %32
    • Gently pull the Wifi card cover off of the camera body.
  16. Nikon COOLPIX P2 WiFi Card Replacement: passo 16, imagem 1 %32
    • Remove the screw holding the Wifi Card to the camera body.
  17. Nikon COOLPIX P2 WiFi Card Replacement: passo 17, imagem 1 %32
    • Gently pull the WiFi card out of the camera.
Conclusão
Joshua Avery
Membro desde: 01/23/12
31 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 3-28, Amido Winter 2012 Membro de Cal Poly, Team 3-28, Amido Winter 2012
CPSU-AMIDO-W12S3G28
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 881
