Ir para o conteúdo principal
Nikon 1 J3 LCD Screen Replacement
O que você precisa
    1. Nikon 1 J3 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32 Nikon 1 J3 LCD Screen Replacement, LCD Screen: passo 1, imagem 2 %32
      • Using a Phillips #000 screwdriver, remove the three bottom screws connected to the back plate on the bottom of the device.
      • Remove the screws under the flaps covering the HDMI and mini USB ports.
      Pergunte ao FixBot
      Comentar
    2. Nikon 1 J3 LCD Screen Replacement: passo 2, imagem 1 %32
      • Carefully pry back the back plate.
      • The plastic of the back plate may crack.
      Pergunte ao FixBot
      Comentar
    3. Nikon 1 J3 LCD Screen Replacement: passo 3, imagem 1 %32
      • Lift up the screen, and use a Phillips #000 screwdriver to remove the (6) six screws holding down the underlying metal plate.
      Pergunte ao FixBot
      Comentar
    4. Nikon 1 J3 LCD Screen Replacement: passo 4, imagem 1 %32
      • Pull back the black switch holding the orange screen ribbon in place, and remove the screen.
      Pergunte ao FixBot
      Comentar
Conclusão
Austin Lackey
Membro desde: 09/26/17
506 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S11-G4, Passmore Fall 2017 Membro de USF Tampa, Team S11-G4, Passmore Fall 2017
USFT-PASSMORE-F17S11G4
3 Membros
Autoria de 4 guias
3Comentários do guia
Hey, I’m having trouble removing the back plate on step 2. It seems to be stuck on the side opposite the HDMI and USB ports, any tips for removing it? Thanks!
johnjames460 - Responder Compartilhar
Step 1 seems to mis removal of 2 screws. Check tutorial below:
https://www.lifepixel.com/tutorials/infr...
Marcel Rossewij - Responder Compartilhar
I am about to replace the lcd screen on my J4 - is the method the same as for the J3? And do I need any adhesive?
Nicholas Glover - 2nd April 2023
Nicholas Glover - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 18
Últimos 30 dias: 41
Ao todo: 1,729
