Ir para o conteúdo principal
Nikon 1 AW 1 Buttons Replacement
O que você precisa
  1. Nikon 1 AW 1 Buttons Replacement, Buttons: passo 1, imagem 1 %32 Nikon 1 AW 1 Buttons Replacement, Buttons: passo 1, imagem 2 %32 Nikon 1 AW 1 Buttons Replacement, Buttons: passo 1, imagem 3 %32
    • Using the Phillips PH00 screwdriver, remove the six 4.0mm screws marked in red. Then remove the panel cover by lightly pulling it off.
    Pergunte ao FixBot
    Comentar
  2. Nikon 1 AW 1 Buttons Replacement: passo 2, imagem 1 %32 Nikon 1 AW 1 Buttons Replacement: passo 2, imagem 2 %32 Nikon 1 AW 1 Buttons Replacement: passo 2, imagem 3 %32
    • Using the Phillips PH00 screwdriver, remove the four 5.5mm screws in the red circles. Then use a plastic opening tool to pry off the tripod socket.
    • Remove the metal plate to have access to the 4.9mm screw under the orange circle, use the Phillips PH00 screwdriver to remove it.
    Pergunte ao FixBot
    Comentar
  3. Nikon 1 AW 1 Buttons Replacement: passo 3, imagem 1 %32 Nikon 1 AW 1 Buttons Replacement: passo 3, imagem 2 %32 Nikon 1 AW 1 Buttons Replacement: passo 3, imagem 3 %32
    • Using a T4 head screwdriver remove the three 5.4mm screws marked with the red circles.
    • Use a 1/4" flathead screwdriver or a flat head tool to release the grip attachment screw.
    • Remove the camera strap eyelet.
    Pergunte ao FixBot
    Comentar
  4. Nikon 1 AW 1 Buttons Replacement: passo 4, imagem 1 %32 Nikon 1 AW 1 Buttons Replacement: passo 4, imagem 2 %32 Nikon 1 AW 1 Buttons Replacement: passo 4, imagem 3 %32
    • Remove the grip attachment screw.
    • Use a Phillips PH00 to remove the two 2.4mm screws on the grip attachment slot, then remove the slot.
    Pergunte ao FixBot
    Comentar
  5. Nikon 1 AW 1 Buttons Replacement: passo 5, imagem 1 %32 Nikon 1 AW 1 Buttons Replacement: passo 5, imagem 2 %32 Nikon 1 AW 1 Buttons Replacement: passo 5, imagem 3 %32
    • Use a T4 screwdriver to remove the three 5.4mm screw marked with the red circles and the eyelet strap.
    • Use a plastic opening tool to lift the front camera cover off.
    Pergunte ao FixBot
    Comentar
  6. Nikon 1 AW 1 Buttons Replacement: passo 6, imagem 1 %32 Nikon 1 AW 1 Buttons Replacement: passo 6, imagem 2 %32 Nikon 1 AW 1 Buttons Replacement: passo 6, imagem 3 %32
    • Use a Phillips PH00 to unscrew the two 3.5mm screws in red.
    • Press the flash pop-up button in the orange rectangle to be able to remove top cover of the camera.
    Pergunte ao FixBot
    Comentar
  7. Nikon 1 AW 1 Buttons Replacement: passo 7, imagem 1 %32 Nikon 1 AW 1 Buttons Replacement: passo 7, imagem 2 %32 Nikon 1 AW 1 Buttons Replacement: passo 7, imagem 3 %32
    • Use a plastic opening tool to lift off the top panel.
    Pergunte ao FixBot
    Comentar
  8. Nikon 1 AW 1 Buttons Replacement: passo 8, imagem 1 %32
    • If you needed to replace any buttons, you may now do so by pulling them off.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team 3-4, Sullivan Fall 2016 Membro de USF Tampa, Team 3-4, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G4
4 Membros
Autoria de 6 guias
1Comentário do guia
What if the flash button is not working? How will i open or fix it? Flash does not pop out
Noel Marantan - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 41
Ao todo: 1,224
