Ir para o conteúdo principal
Nike SportWatch GPS Back Panel Replacement
O que você precisa
    1. Nike SportWatch GPS Back Panel Replacement, Back Panel: passo 1, imagem 1 %32
      • Face the watch upside down, so that the back of the watch is exposed. Unscrew the six #000 size 5 mm long screws on the back using a size 000 Phillips head screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Nike SportWatch GPS Back Panel Replacement: passo 2, imagem 1 %32
      • Carefully separate the watch by pulling the band away from the main board.
      Pergunte ao FixBot
      Comentar
    3. Nike SportWatch GPS Back Panel Replacement: passo 3, imagem 1 %32
      • Pry the black plastic piece above the battery out using a nylon or metal spudger.
      • Be careful not to break the metal flat bands located above the plastic piece. They are fragile and easily breakable.
      Pergunte ao FixBot
      Comentar
    4. Nike SportWatch GPS Back Panel Replacement: passo 4, imagem 1 %32
      • Using a guitar pick removal tool, push under the battery to pry the battery out of the watch.
      Pergunte ao FixBot
      Comentar
    5. Nike SportWatch GPS Back Panel Replacement: passo 5, imagem 1 %32
      • After taking the battery out, you will be left with just the band and the backpanel part of the watch.
      Pergunte ao FixBot
      Comentar
Conclusão
Ian Eichorn
Membro desde: 10/22/15
696 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 Membro de UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G8
3 Membros
Autoria de 5 guias
3Comentários do guia
Where can I find a new watch band?
rhalljr68 - Responder Compartilhar
You can´t. Nike left us alone
Leonardo Cartier - Responder Compartilhar
So, no way to repair the band then if there's no replacement parts? :(
roycy Tan - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 31
Ao todo: 2,926
