Ir para o conteúdo principal
Nexus 6P Vibration Motor Replacement
O que você precisa
  1. Nexus 6P Vibration Motor Replacement, Back Cover: passo 1, imagem 1 %32 Nexus 6P Vibration Motor Replacement, Back Cover: passo 1, imagem 2 %32 Nexus 6P Vibration Motor Replacement, Back Cover: passo 1, imagem 3 %32
    • It is possible to remove the back cover with an iOpener as seen in this guide but it's a lengthy and difficult procedure. We recommend a heat gun or something similar. The adhesive in the Nexus 6P is extremely sticky and especially the glass and plastic cover on the backside break or bend most of the time whilst doing this repair.
    • Use a SIM card eject tool, to pop out and remove the SIM card tray.
    • Use an iOpener to loosen the adhesive underneath the small plastic cover at the bottom of the phone.
  2. Nexus 6P Vibration Motor Replacement: passo 2, imagem 1 %32 Nexus 6P Vibration Motor Replacement: passo 2, imagem 2 %32 Nexus 6P Vibration Motor Replacement: passo 2, imagem 3 %32
    • The knife is really sharp. Take care, not to cut yourself or your phone.
    • Insert a knife between the phone and the plastic cover. Pry up the plastic cover until you can insert an opening pick.
    • Slide the opening pick underneath the plastic cover to cut the adhesive.
  3. Nexus 6P Vibration Motor Replacement: passo 3, imagem 1 %32 Nexus 6P Vibration Motor Replacement: passo 3, imagem 2 %32
    • Use an iOpener to loosen the adhesive underneath the glass cover at the top of the phone.
    • Insert a knife between the phone and the glass cover. Pry up the glass cover until you can insert an opening pick.
  4. Nexus 6P Vibration Motor Replacement: passo 4, imagem 1 %32 Nexus 6P Vibration Motor Replacement: passo 4, imagem 2 %32 Nexus 6P Vibration Motor Replacement: passo 4, imagem 3 %32
    • Glass may break. Wear protective glasses and protective gloves.
    • Slide the opening pick underneath the glass cover and use it to cut the adhesive underneath.
    • Pry off the glass cover.
  5. Nexus 6P Vibration Motor Replacement: passo 5, imagem 1 %32 Nexus 6P Vibration Motor Replacement: passo 5, imagem 2 %32 Nexus 6P Vibration Motor Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Remove the six Phillips #00 screws.
    • Use tweezers to remove any stickers covering the screw to allow better seating for the driver.
  6. Nexus 6P Vibration Motor Replacement: passo 6, imagem 1 %32 Nexus 6P Vibration Motor Replacement: passo 6, imagem 2 %32 Nexus 6P Vibration Motor Replacement: passo 6, imagem 3 %32
    • Insert a razor knife between the metal back cover and the front glass to create a gap. Insert an opening pick into the gap and slide it to the top right corner.
    • The knife is really sharp, be careful, not to cut yourself or your phone.
    • Insert a second opening pick and slide it to the top left corner.
    • Slide the opening picks along the edges to seperate the plastic clips, holding back cover and midframe together.
    • Remove the rear cover.
  7. Nexus 6P Vibration Motor Replacement, Battery Disconnection: passo 7, imagem 1 %32 Nexus 6P Vibration Motor Replacement, Battery Disconnection: passo 7, imagem 2 %32 Nexus 6P Vibration Motor Replacement, Battery Disconnection: passo 7, imagem 3 %32
    • Remove the Philipps #000 screw.
    • Use tweezers to remove the metal plate.
    • Use the flat end of a spudger, to disconnect the battery flex cable.
  8. Nexus 6P Vibration Motor Replacement, Charging Board: passo 8, imagem 1 %32 Nexus 6P Vibration Motor Replacement, Charging Board: passo 8, imagem 2 %32 Nexus 6P Vibration Motor Replacement, Charging Board: passo 8, imagem 3 %32
    • Disconnect the main flex cable with a spudger.
    • Use tweezers to unplug the antenna cable.
    • Remove the Phillips #000 screw.
  9. Nexus 6P Vibration Motor Replacement: passo 9, imagem 1 %32 Nexus 6P Vibration Motor Replacement: passo 9, imagem 2 %32
    • Pry out the charging board with a spudger.
    • Remove the charging board.
  10. Nexus 6P Vibration Motor Replacement, Vibration Motor: passo 10, imagem 1 %32
    • Use tweezers to remove the vibration motor. There is some adhesive underneath so it might be a little bit sticky.
    • When reassembling apply new adhesive where it's necessary.
Conclusão
To reassemble your device, follow these instructions in reverse order. When reassembling apply new adhesive where it's necessary.
Theo Mat
Membro desde: 11/12/17
12.951 Reputação
Autoria de 14 guias
3Comentários do guia
My vibraiton motor is broken. I can’t find pefertly same motor in the internet . Can I use this vibriaton motor for replace
Derrick Ian - Responder
Hi Derrick,
it isn’t very advisable to buy a spare part, that doesn’t say it’s exactly for the Nexus 6P. It can happen that it doesn’t fit in the bracket for the vibrator in your phone or that it doesn’t work with it. Worst case scenario is, that it’ll cause higher damage to you phone than repair.
Dominik Schnabelrauch -
I design vibration machines. My vibrator motor is not easy to use. Do you have anything to recommend? Large vibrating motors are not used on mobile phones.
mclana - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 126
Ao todo: 1,450
