Ir para o conteúdo principal
Nexus 6P Loudspeaker Replacement
O que você precisa
  1. Nexus 6P Loudspeaker Replacement, Back Cover: passo 1, imagem 1 %32 Nexus 6P Loudspeaker Replacement, Back Cover: passo 1, imagem 2 %32 Nexus 6P Loudspeaker Replacement, Back Cover: passo 1, imagem 3 %32
    • It is possible to remove the back cover with an iOpener as seen in this guide but it's a lengthy and difficult procedure. We recommend a heat gun or something similar. The adhesive in the Nexus 6P is extremely sticky and especially the glass and plastic cover on the backside break or bend most of the time whilst doing this repair.
    • Use a SIM card eject tool, to pop out and remove the SIM card tray.
    • Use an iOpener to loosen the adhesive underneath the small plastic cover at the bottom of the phone.
  2. Nexus 6P Loudspeaker Replacement: passo 2, imagem 1 %32 Nexus 6P Loudspeaker Replacement: passo 2, imagem 2 %32 Nexus 6P Loudspeaker Replacement: passo 2, imagem 3 %32
    • The knife is really sharp. Take care, not to cut yourself or your phone.
    • Insert a knife between the phone and the plastic cover. Pry up the plastic cover until you can insert an opening pick.
    • Slide the opening pick underneath the plastic cover to cut the adhesive.
  3. Nexus 6P Loudspeaker Replacement: passo 3, imagem 1 %32 Nexus 6P Loudspeaker Replacement: passo 3, imagem 2 %32
    • Use an iOpener to loosen the adhesive underneath the glass cover at the top of the phone.
    • Insert a knife between the phone and the glass cover. Pry up the glass cover until you can insert an opening pick.
  4. Nexus 6P Loudspeaker Replacement: passo 4, imagem 1 %32 Nexus 6P Loudspeaker Replacement: passo 4, imagem 2 %32 Nexus 6P Loudspeaker Replacement: passo 4, imagem 3 %32
    • Glass may break. Wear protective glasses and protective gloves.
    • Slide the opening pick underneath the glass cover and use it to cut the adhesive underneath.
    • Pry off the glass cover.
  5. Nexus 6P Loudspeaker Replacement: passo 5, imagem 1 %32 Nexus 6P Loudspeaker Replacement: passo 5, imagem 2 %32 Nexus 6P Loudspeaker Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Remove the six Phillips #00 screws.
    • Use tweezers to remove any stickers covering the screw to allow better seating for the driver.
  6. Nexus 6P Loudspeaker Replacement: passo 6, imagem 1 %32 Nexus 6P Loudspeaker Replacement: passo 6, imagem 2 %32 Nexus 6P Loudspeaker Replacement: passo 6, imagem 3 %32
    • Insert a razor knife between the metal back cover and the front glass to create a gap. Insert an opening pick into the gap and slide it to the top right corner.
    • The knife is really sharp, be careful, not to cut yourself or your phone.
    • Insert a second opening pick and slide it to the top left corner.
    • Slide the opening picks along the edges to seperate the plastic clips, holding back cover and midframe together.
    • Remove the rear cover.
  7. Nexus 6P Loudspeaker Replacement, Battery Disconnection: passo 7, imagem 1 %32 Nexus 6P Loudspeaker Replacement, Battery Disconnection: passo 7, imagem 2 %32 Nexus 6P Loudspeaker Replacement, Battery Disconnection: passo 7, imagem 3 %32
    • Remove the Philipps #000 screw.
    • Use tweezers to remove the metal plate.
    • Use the flat end of a spudger, to disconnect the battery flex cable.
  8. Nexus 6P Loudspeaker Replacement, Charging Board: passo 8, imagem 1 %32 Nexus 6P Loudspeaker Replacement, Charging Board: passo 8, imagem 2 %32 Nexus 6P Loudspeaker Replacement, Charging Board: passo 8, imagem 3 %32
    • Disconnect the main flex cable with a spudger.
    • Use tweezers to unplug the antenna cable.
    • Remove the Phillips #000 screw.
  9. Nexus 6P Loudspeaker Replacement: passo 9, imagem 1 %32 Nexus 6P Loudspeaker Replacement: passo 9, imagem 2 %32
    • Pry out the charging board with a spudger.
    • Remove the charging board.
  10. Nexus 6P Loudspeaker Replacement, Loudspeaker: passo 10, imagem 1 %32 Nexus 6P Loudspeaker Replacement, Loudspeaker: passo 10, imagem 2 %32 Nexus 6P Loudspeaker Replacement, Loudspeaker: passo 10, imagem 3 %32
    • Unscrew the Philipps #000 screw.
    • There is some adhesive beneath the loudspeaker, especially under the small flex cable on its side. Don't damage or rip the cable while you remove it.
    • Use the flat end of a spudger to pry off the loudspeaker.
    • Use tweezers to grab the loudspeaker and remove it.
Conclusão
To reassemble your device, follow these instructions in reverse order. When reassembling apply new adhesive where it's necessary.
Uma outra pessoa concluiu este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
229.601 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.465 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 883
