Introdução
Use this guide to replace the headphone jack in your Nexus 6P smartphone. When reassembling your phone apply new adhesive where it is necessary.
O que você precisa
Use a SIM card eject tool, to pop out and remove the SIM card tray.
Use an iOpener to loosen the adhesive underneath the small plastic cover at the bottom of the phone.
Use an iOpener to loosen the adhesive underneath the glass cover at the top of the phone.
Insert a knife between the phone and the glass cover. Pry up the glass cover until you can insert an opening pick.
Insert a razor knife between the metal back cover and the front glass to create a gap. Insert an opening pick into the gap and slide it to the top right corner.
Insert a second opening pick and slide it to the top left corner.
Slide the opening picks along the edges to seperate the plastic clips, holding back cover and midframe together.
Remove the rear cover.
Remove the Philipps #000 screw.
Use tweezers to remove the metal plate.
Use the flat end of a spudger, to disconnect the battery flex cable.
Unscrew the two Philipps #000 screws.
Use tweezers to disconnect the antenna cable.
Remove the metal plate covering the front facing camera and the headphone jack.
Uma outra pessoa concluiu este guia.
