Ir para o conteúdo principal
Nexus 5X Front-Facing Camera Replacement
O que você precisa
  1. Nexus 5X Front-Facing Camera Replacement, SIM Card Tray: passo 1, imagem 1 %32 Nexus 5X Front-Facing Camera Replacement, SIM Card Tray: passo 1, imagem 2 %32 Nexus 5X Front-Facing Camera Replacement, SIM Card Tray: passo 1, imagem 3 %32
    • Insert a SIM card ejection tool into the hole on the SIM card tray, located on the left edge of the phone.
    • Press in to eject the SIM card tray.
    • Remove the SIM card tray.
    Pergunte ao FixBot
    Comentar
  2. Nexus 5X Front-Facing Camera Replacement, Rear Panel: passo 2, imagem 1 %32 Nexus 5X Front-Facing Camera Replacement, Rear Panel: passo 2, imagem 2 %32 Nexus 5X Front-Facing Camera Replacement, Rear Panel: passo 2, imagem 3 %32
    • Place an opening pick in the opening of the SIM card tray slot and twist it sideways to release the first plastic clip that holds the rear panel in its place.
    • Slide the opening pick around the top edge of the phone to release the plastic clips that secure the rear panel.
    Pergunte ao FixBot
    Comentar
  3. Nexus 5X Front-Facing Camera Replacement: passo 3, imagem 1 %32 Nexus 5X Front-Facing Camera Replacement: passo 3, imagem 2 %32 Nexus 5X Front-Facing Camera Replacement: passo 3, imagem 3 %32
    • Continue to slide the opening pick around all sides of the phone to release all clips that secure the rear panel.
    Pergunte ao FixBot
    Comentar
  4. Nexus 5X Front-Facing Camera Replacement: passo 4, imagem 1 %32 Nexus 5X Front-Facing Camera Replacement: passo 4, imagem 2 %32
    • Tilt the opening pick to lift the rear panel a little bit.
    • There are two more plastic clips next to the fingerprint sensor. Release them by gently pulling the rear panel.
    • Remove the rear panel.
    Pergunte ao FixBot
    Comentar
  5. Nexus 5X Front-Facing Camera Replacement, Midframe: passo 5, imagem 1 %32
    • Remove the ten 3.6 mm Phillips screws that secure the midframe.
    Pergunte ao FixBot
    Comentar
  6. Nexus 5X Front-Facing Camera Replacement: passo 6, imagem 1 %32 Nexus 5X Front-Facing Camera Replacement: passo 6, imagem 2 %32
    • Insert an opening pick into the SIM card tray slot and twist the opening pick sideways to release the plastic clips.
    Pergunte ao FixBot
    Comentar
  7. Nexus 5X Front-Facing Camera Replacement: passo 7, imagem 1 %32 Nexus 5X Front-Facing Camera Replacement: passo 7, imagem 2 %32
    • Continue sliding the opening pick around the upper part of the midframe to release the plastic clips.
    Pergunte ao FixBot
    Comentar
  8. Nexus 5X Front-Facing Camera Replacement: passo 8, imagem 1 %32 Nexus 5X Front-Facing Camera Replacement: passo 8, imagem 2 %32
    • Use the plastic pick to pry open the plastic clips on the long edge of the midframe and on the bottom edge.
    • Make sure the clips on the long edge are released. The midframe is prone to break here if they are not disconnected properly.
    Pergunte ao FixBot
    Comentar
  9. Nexus 5X Front-Facing Camera Replacement: passo 9, imagem 1 %32 Nexus 5X Front-Facing Camera Replacement: passo 9, imagem 2 %32
    • Make sure all the clips are free.
    • Carefully remove the midframe.
    Pergunte ao FixBot
    Comentar
  10. Nexus 5X Front-Facing Camera Replacement, Battery Disconnect: passo 10, imagem 1 %32 Nexus 5X Front-Facing Camera Replacement, Battery Disconnect: passo 10, imagem 2 %32
    • Use the edge of a spudger to pry up and disconnect the battery flex cable located at the bottom right of the motherboard.
    Pergunte ao FixBot
    Comentar
  11. Nexus 5X Front-Facing Camera Replacement, Front Facing Camera: passo 11, imagem 1 %32 Nexus 5X Front-Facing Camera Replacement, Front Facing Camera: passo 11, imagem 2 %32
    • Use the flat end of a spudger to pry up and disconnect the front-facing camera flex cable.
    Pergunte ao FixBot
    Comentar
  12. Nexus 5X Front-Facing Camera Replacement: passo 12, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers to remove the front-facing camera from its recess.
    Pergunte ao FixBot
    Comentar
Conclusão
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
Repair didn’t go as planned? Check out our Nexus 5X Answers community for troubleshooting help.
3 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
260.237 Reputação
Autoria de 682 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 67
Ao todo: 2,767
