Ir para o conteúdo principal
Nexus 4 Power and Volume Button Replacement
O que você precisa
  1. Nexus 4 Power and Volume Button Replacement, Back Cover: passo 1, imagem 1 %32 Nexus 4 Power and Volume Button Replacement, Back Cover: passo 1, imagem 2 %32
    Ferramenta utilizada neste passo:
    SIM Card Eject Tool
    $2.99
    • Power off the phone, by long-pressing the power button and touching Power off.
    • Remove the SIM tray using the SIM Card Eject Tool.
    • This step is required in order to remove the back case.
    Pergunte ao FixBot
    Comentar
  2. Nexus 4 Power and Volume Button Replacement: passo 2, imagem 1 %32
    T5 Torx Screwdriver
    $5.49
    Pergunte ao FixBot
    Comentar
  3. Nexus 4 Power and Volume Button Replacement: passo 3, imagem 1 %32 Nexus 4 Power and Volume Button Replacement: passo 3, imagem 2 %32 Nexus 4 Power and Volume Button Replacement: passo 3, imagem 3 %32
    • Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
    • The opening process may take a few minutes. The plastic will make a light snapping noise as the back cover separates from the rest of the phone.
    Pergunte ao FixBot
    Comentar
  4. Nexus 4 Power and Volume Button Replacement, Power and Volume Button: passo 4, imagem 1 %32 Nexus 4 Power and Volume Button Replacement, Power and Volume Button: passo 4, imagem 2 %32
    • Holding the back case, gently push the power button in towards the center of the phone using a spudger.
    Pergunte ao FixBot
    Comentar
  5. Nexus 4 Power and Volume Button Replacement: passo 5, imagem 1 %32 Nexus 4 Power and Volume Button Replacement: passo 5, imagem 2 %32 Nexus 4 Power and Volume Button Replacement: passo 5, imagem 3 %32
    • To remove the volume button, push the button in towards the center of the phone using a spudger.
    Pergunte ao FixBot
    Comentar
Conclusão
16 outras pessoas executaram este guia.
Kaitlyn Jones
Membro desde: 01/27/13
4.964 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 3-32, Amido Winter 2013 Membro de Cal Poly, Team 3-32, Amido Winter 2013
CPSU-AMIDO-W13S3G32
4 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 9
Últimos 30 dias: 61
Ao todo: 30,350
