Ir para o conteúdo principal
Nexus 4 Plastic Midframe Replacement
O que você precisa
  1. Nexus 4 Plastic Midframe Replacement, Back Cover: passo 1, imagem 1 %32 Nexus 4 Plastic Midframe Replacement, Back Cover: passo 1, imagem 2 %32
    Ferramenta utilizada neste passo:
    SIM Card Eject Tool
    $2.99
    • Power off the phone, by long-pressing the power button and touching Power off.
    • Remove the SIM tray using the SIM Card Eject Tool.
    • This step is required in order to remove the back case.
    Pergunte ao FixBot
    Comentar
  2. Nexus 4 Plastic Midframe Replacement: passo 2, imagem 1 %32
    T5 Torx Screwdriver
    $5.49
    Pergunte ao FixBot
    Comentar
  3. Nexus 4 Plastic Midframe Replacement: passo 3, imagem 1 %32 Nexus 4 Plastic Midframe Replacement: passo 3, imagem 2 %32 Nexus 4 Plastic Midframe Replacement: passo 3, imagem 3 %32
    • Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
    • The opening process may take a few minutes. The plastic will make a light snapping noise as the back cover separates from the rest of the phone.
    Pergunte ao FixBot
    Comentar
  4. Nexus 4 Plastic Midframe Replacement, Battery: passo 4, imagem 1 %32 Nexus 4 Plastic Midframe Replacement, Battery: passo 4, imagem 2 %32
    • Remove the two 1.8 mm Phillips screws holding down the battery connector.
    • Using a plastic opening tool, disconnect the battery cable from its socket on the motherboard.
    Pergunte ao FixBot
    Comentar
  5. Nexus 4 Plastic Midframe Replacement, Battery removal: passo 5, imagem 1 %32 Nexus 4 Plastic Midframe Replacement, Battery removal: passo 5, imagem 2 %32
    Plastic Cards
    $2.99
    • Remove the blue tape that secures the white antenna cable to the battery.
    • Using a spudger, carefully disconnect the white antenna cable.
    • Carefully pry the battery out with a Plastic Opening Tool, starting at the top left-hand corner and working down towards the bottom right-hand corner.
    • If necessary, you can also use a plastic card to separate the battery from the metal midframe.
    • The battery is securely glued to the phone. When reinstalling the battery, press the battery firmly against the adhesive strip.
    Pergunte ao FixBot
    Comentar
  6. Nexus 4 Plastic Midframe Replacement, Plastic Midframe: passo 6, imagem 1 %32 Nexus 4 Plastic Midframe Replacement, Plastic Midframe: passo 6, imagem 2 %32 Nexus 4 Plastic Midframe Replacement, Plastic Midframe: passo 6, imagem 3 %32
    • Remove the nine 4.6 mm Phillips #000 screws. Gently lift out the plastic cover.
    • The midframe is held in with two clips, one at either side. Use a plastic spudger to release each side and gently lift up and away.
    Pergunte ao FixBot
    Comentar
Conclusão
7 outras pessoas executaram este guia.
Kaitlyn Jones
Membro desde: 01/27/13
4.964 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 3-32, Amido Winter 2013 Membro de Cal Poly, Team 3-32, Amido Winter 2013
CPSU-AMIDO-W13S3G32
4 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 40
Ao todo: 11,573
