Ir para o conteúdo principal
Nextbook Premium 7SE Volume Buttons Replacement
O que você precisa
  1. Nextbook Premium 7SE Volume Buttons Replacement, Back Cover: passo 1, imagem 1 %32 Nextbook Premium 7SE Volume Buttons Replacement, Back Cover: passo 1, imagem 2 %32 Nextbook Premium 7SE Volume Buttons Replacement, Back Cover: passo 1, imagem 3 %32
    • Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
    • Slide the opening tool to the right and slowly continue to separate the back cover from the device.
    • Avoid prying on the buttons, as they are easily damaged.
  2. Nextbook Premium 7SE Volume Buttons Replacement: passo 2, imagem 1 %32
    • Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
  3. Nextbook Premium 7SE Volume Buttons Replacement, Battery: passo 3, imagem 1 %32
    • Remove masking tape from the battery.
  4. Nextbook Premium 7SE Volume Buttons Replacement: passo 4, imagem 1 %32 Nextbook Premium 7SE Volume Buttons Replacement: passo 4, imagem 2 %32 Nextbook Premium 7SE Volume Buttons Replacement: passo 4, imagem 3 %32
    • Pry the battery from the base using the nylon spudger and move it away from the motherboard.
    • Handle the battery with care to avoid damaging it.
  5. Nextbook Premium 7SE Volume Buttons Replacement: passo 5, imagem 1 %32 Nextbook Premium 7SE Volume Buttons Replacement: passo 5, imagem 2 %32 Nextbook Premium 7SE Volume Buttons Replacement: passo 5, imagem 3 %32
    • De-solder the three contact points and remove the battery.
    • See the following guide for instructions on how to solder. Como soldar e dessoldar contatos
    • Use caution when operating the soldering iron.
  6. Nextbook Premium 7SE Volume Buttons Replacement, Motherboard: passo 6, imagem 1 %32 Nextbook Premium 7SE Volume Buttons Replacement, Motherboard: passo 6, imagem 2 %32 Nextbook Premium 7SE Volume Buttons Replacement, Motherboard: passo 6, imagem 3 %32
    • Remove the two ZIF connectors attached to the motherboard by flipping up the black tabs before pulling the ribbon cable away.
    • Only use a fingernail or nylon spudger to flip up the retaining flap. Using metal tools may damage delicate components.
  7. Nextbook Premium 7SE Volume Buttons Replacement: passo 7, imagem 1 %32
    • Use the nut driver and J00 bit to remove the three 4 mm screws.
  8. Nextbook Premium 7SE Volume Buttons Replacement: passo 8, imagem 1 %32 Nextbook Premium 7SE Volume Buttons Replacement: passo 8, imagem 2 %32 Nextbook Premium 7SE Volume Buttons Replacement: passo 8, imagem 3 %32
    • Peel back metal tape that is hiding the auxiliary port wires.
    • Remove tape that is holding the speaker wires in place.
    • Lift up on the motherboard to release it from the tablet.
  9. Nextbook Premium 7SE Volume Buttons Replacement, Volume Buttons: passo 9, imagem 1 %32
    • De-solder volume buttons' eight contact points.
    • Each button has 4 points of contact.
Conclusão
Michelle Helweh
Membro desde: 10/30/16
214 Reputação
Autoria de 2 guias
Equipe
Baylor, Team 4-1, Williams Fall 2016 Membro de Baylor, Team 4-1, Williams Fall 2016
BU-WILLIAMS-F16S4G1
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 181
