Introdução
In order to access the components of your device, you will need to remove the back cover. This guide will help you accomplish this in a few simple steps.
O que você precisa
Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
Slide the opening tool to the right and slowly continue to separate the back cover from the device.
Remove the two ZIF connectors attached to the motherboard by flipping up the black tabs before pulling the ribbon cable away.
Flip the motherboard over and locate the Micro USB port once the motherboard has been detached
De-solder the three contact points and remove the port.
Uma outra pessoa concluiu este guia.
