Introdução
Use this guide to replace a broken speaker.This replacement guide requires a Soldering Iron, it would be very helpful to heat the iron up before starting this guide, this process can take 3-4 minutes. You should refer to iFixit's soldering guide to help with the desoldering/soldering process.
O que você precisa
Using your finger, open the plastic tab to the right of the rear-facing camera.
Wedge your fingernail in between the back panel and the plastic tab and pull the plastic tab towards your body.
Remove yellow tape with a black edge that covers the red, white and black wires.
Uma outra pessoa concluiu este guia.
