Ir para o conteúdo principal
Newport e360 Exhalation Flow Sensor Replacement
O que você precisa
  1. Newport e360 Exhalation Flow Sensor Replacement, Exhalation Flow Sensor: passo 1, imagem 1 %32
    • Turn off ventilator before starting this repair.
    • Shut off or disconnect the air and oxygen gas supplies before starting this repair.
    Pergunte ao FixBot
    Comentar
  2. Newport e360 Exhalation Flow Sensor Replacement: passo 2, imagem 1 %32
    • To avoid damaging equipment, always use standard electrostatic discharge (ESD) precautions
    • Put on an ESD wrist strap or ESD gloves
    Pergunte ao FixBot
    Comentar
  3. Newport e360 Exhalation Flow Sensor Replacement: passo 3, imagem 1 %32
    • Open the Front Panel Door on the lower left front of the ventilator to expose Exhalation Valve EXH2105A and Flow Sensor FLS2101P.
    Pergunte ao FixBot
    Comentar
  4. Newport e360 Exhalation Flow Sensor Replacement: passo 4, imagem 1 %32
    • Remove the Exhalation Valve EXH2105A by releasing the retaining latch.
    Pergunte ao FixBot
    Comentar
  5. Newport e360 Exhalation Flow Sensor Replacement: passo 5, imagem 1 %32
    • Disconnect the Flow Sensor Cable CBL2123P from the plastic body of the Flow Sensor FLS2101P by pulling cable straight up. Do not twist.
    Pergunte ao FixBot
    Comentar
  6. Newport e360 Exhalation Flow Sensor Replacement: passo 6, imagem 1 %32
    • With a twisting motion, pull the plastic Flow Sensor FLS2101P away from the outlet of the Exhalation Valve EXH2105A.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Lauren Ochoa
Membro desde: 04/13/20
192 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S7-G21, Paton Spring 2020 Membro de Cal Poly, Team S7-G21, Paton Spring 2020
CPSU-PATON-S20S7G21
3 Membros
Autoria de 3 guias
2Comentários do guia
I need this Exhalation Valve EXH2105A part, does anyone have a replacement?
Remigio Rodriguez - Responder Compartilhar
I need this
Cable NEWPORT GR-CBL2123P Flow Meter Parts P/N GR-CBL2123P
Please confirmwd to edisonmanullang@gmail.com
Thanks
Edison Simanullang - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 34
Ao todo: 857
