Ir para o conteúdo principal
New Nintendo 2DS XL Touchscreen Replacement
O que você precisa
  1. New Nintendo 2DS XL Touchscreen Replacement, Back Cover Removal Preparation: passo 1, imagem 1 %32
    • Before starting the disassembly, remove
    • The stylus
    • Any game cartridge
    • The microSD card
    Pergunte ao FixBot
  2. New Nintendo 2DS XL Touchscreen Replacement, Back Cover Removal: passo 2, imagem 1 %32
    • Use a tri‑point Y00 screwdriver to unscrew the four 6 mm‑long screws located at the four corners of the bottom panel.
    Pergunte ao FixBot
  3. New Nintendo 2DS XL Touchscreen Replacement, Case Separation: passo 3, imagem 1 %32 New Nintendo 2DS XL Touchscreen Replacement, Case Separation: passo 3, imagem 2 %32
    • Be careful when separating the bottom panel from the front casing to avoid breaking the three cables connected to the motherboard (two on each side and one in the rear).
    • Using a spudger, separate the back panel from the front casing by gently prying around the panel.
    • There are many clips along the hinge of the case, so it is recommended to work your way along one short side and the two long sides before finishing the last short side.
    Pergunte ao FixBot
  4. New Nintendo 2DS XL Touchscreen Replacement: passo 4, imagem 1 %32 New Nintendo 2DS XL Touchscreen Replacement: passo 4, imagem 2 %32 New Nintendo 2DS XL Touchscreen Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to disconnect the two cables that connect the rear buttons on either side to the motherboard by gently pulling them upwards.
    Pergunte ao FixBot
  5. New Nintendo 2DS XL Touchscreen Replacement, Battery Removal: passo 5, imagem 1 %32 New Nintendo 2DS XL Touchscreen Replacement, Battery Removal: passo 5, imagem 2 %32
    • The battery is lightly adhered to its enclosure.
    • Use the flat end of a spudger to gently pry the battery out of its plastic enclosure.
    Pergunte ao FixBot
  6. New Nintendo 2DS XL Touchscreen Replacement, Motherboard: passo 6, imagem 1 %32 New Nintendo 2DS XL Touchscreen Replacement, Motherboard: passo 6, imagem 2 %32
    • There are 8 ribbon cables that need to be removed as shown in the picture.
    • 2 of connectors (in green) are friction fit, unlike the rest of the connectors. Remove the cable by pulling it out gently flat in the arrow direction. Do not attempt to open or unlatch these connectors in any way. Doing so will break them.
    • For the remaining 6 (in red), use a pair of tweezers to flip the latches up and pull the ribbon cable out.
    • Note that the second picture shows a broken ribbon connector next to the joystick ribbon connector (to the right of the red arrow). Do not attempt to unlatch this connector as shown in the picture!
    Pergunte ao FixBot
  7. New Nintendo 2DS XL Touchscreen Replacement: passo 7, imagem 1 %32 New Nintendo 2DS XL Touchscreen Replacement: passo 7, imagem 2 %32
    • Unplug the following wires from the motherboard using a pair of tweezers.
    Pergunte ao FixBot
  8. New Nintendo 2DS XL Touchscreen Replacement: passo 8, imagem 1 %32 New Nintendo 2DS XL Touchscreen Replacement: passo 8, imagem 2 %32
    • Remove the seven 4.4 mm screws using a J00 (or iFixit's Phillips #00) screwdriver bit.
    • Remove the motherboard from the device.
    Pergunte ao FixBot
  9. New Nintendo 2DS XL Touchscreen Replacement, Touchscreen: passo 9, imagem 1 %32 New Nintendo 2DS XL Touchscreen Replacement, Touchscreen: passo 9, imagem 2 %32
    • Remove the five 7.5mm phillips screws using a PH000 screwdriver.
    • Using tweezers, pull up the plate covering the touchpad. The center ribbon cable will slide through this plate.
    Pergunte ao FixBot
  10. New Nintendo 2DS XL Touchscreen Replacement: passo 10, imagem 1 %32 New Nintendo 2DS XL Touchscreen Replacement: passo 10, imagem 2 %32
    • The bottom screen is stuck to the front with an adhesive border. Be careful to slowly separate the two. Quick separation can damage both components.
    • Using tweezers, pry up the touchscreen.
    Pergunte ao FixBot
Conclusão
18 outras pessoas executaram este guia.
Tim Newman
Membro desde: 09/25/17
2.012 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S18-G6, Forte Fall 2017 Membro de Cal Poly, Team S18-G6, Forte Fall 2017
CPSU-FORTE-F17S18G6
5 Membros
Autoria de 24 guias
12Comentários do guia
Please do top screen next, that’s what I need, but still +30 points :)
Multimegamander - Responder Compartilhar
Hi Bud
Great instructions, but where do you buy 2ds xl replacement screens. I’ve looked everywhere. I only see 2ds and 3dsxl replacements for sale
Thanks
John
John S - Responder Compartilhar
Where can you find the screen replacements?
Caleb Riley - Responder Compartilhar
Where can you find the screen replacements? This is a great guide but I can't find the screen replacements anywhere.
Comentar
Visualizações:
Últimas 24 horas: 18
Últimos 7 dias: 113
Últimos 30 dias: 539
Ao todo: 28,337
