Ir para o conteúdo principal
NeuTab N9 Speaker Replacement
O que você precisa
  1. NeuTab N9 Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Turn off your device before beginning these steps.
    • Insert the plastic opening tool into the seam between the screen and the back of the tablet. Move the opening tool along the seam until the back of the tablet releases.
  2. NeuTab N9 Speaker Replacement: passo 2, imagem 1 %32 NeuTab N9 Speaker Replacement: passo 2, imagem 2 %32
    • The speaker should be magnetically attached to the back.
    • Remove the positive and negative wires connecting the speaker to the motherboard with the soldering gun. Follow these instructions if you do not already know how to desolder.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 96
