Ir para o conteúdo principal
NeuTab N9 Motherboard Replacement
O que você precisa
  1. NeuTab N9 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Turn off your device before beginning these steps.
    • Insert the plastic opening tool into the seam between the screen and the back of the tablet. Move the opening tool along the seam until the back of the tablet releases.
  2. NeuTab N9 Motherboard Replacement: passo 2, imagem 1 %32
    • Use the soldering gun to separate all soldered wires from the motherboard.
    • For a complete guide on how to solder, click here.
  3. NeuTab N9 Motherboard Replacement: passo 3, imagem 1 %32
    • Use a spudger to carefully release the tabs on the three ZIF connectors securing the ribbon cables to the motherboard.
    • Carefully pull the ribbons out.
  4. NeuTab N9 Motherboard Replacement: passo 4, imagem 1 %32
    • Use the Phillips #0 screwdriver to remove the three 1 mm screws from the motherboard.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 232
