Ir para o conteúdo principal
NeuTab N7 Pro Speaker Replacement
O que você precisa
  1. NeuTab N7 Pro Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Power off your device before beginning disassembly.
    • Insert plastic opening tool and pry back case away from the device, slowly moving the plastic opening tool along the device.
  2. NeuTab N7 Pro Speaker Replacement: passo 2, imagem 1 %32 NeuTab N7 Pro Speaker Replacement: passo 2, imagem 2 %32
    • The speaker is attached to the back cover of the device.
    • Hold positive and negative wires as close as possible to the speaker. Use small plastic spudger and fingers to simultaneously lift speaker from cover.
  3. NeuTab N7 Pro Speaker Replacement: passo 3, imagem 1 %32 NeuTab N7 Pro Speaker Replacement: passo 3, imagem 2 %32 NeuTab N7 Pro Speaker Replacement: passo 3, imagem 3 %32
    • Use a soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
    • For a complete guide on how to solder, click here.
    • Be sure not to touch both the positive and negative terminal at the same time.
Conclusão
Uma outra pessoa concluiu este guia.
Travis McLean
Membro desde: 02/09/16
322 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 7-1, Cheng Spring 2016 Membro de USF Tampa, Team 7-1, Cheng Spring 2016
USFT-CHENG-S16S7G1
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 263
