Ir para o conteúdo principal
NeuTab N7 Pro Camera Replacement
O que você precisa
    1. NeuTab N7 Pro Camera Replacement, Camera: passo 1, imagem 1 %32
      • Power off your device before beginning disassembly
      • Insert plastic opening tool and pry back case away, slowly moving the plastic opening tool along the device.
      Pergunte ao FixBot
      Comentar
    2. NeuTab N7 Pro Camera Replacement: passo 2, imagem 1 %32
      • Locate the camera unit and note where it is attached to the motherboard.
      • Use a black nylon spudger to remove the adhesive holding it onto to the motherboard.
      • Metal tools can puncture an unprotected battery, potentially causing a fire. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device.
      Pergunte ao FixBot
      Comentar
    3. NeuTab N7 Pro Camera Replacement: passo 3, imagem 1 %32 NeuTab N7 Pro Camera Replacement: passo 3, imagem 2 %32
      Ferramenta utilizada neste passo:
      • Use a black nylon spudger or tweezers to release the connector holding the camera ribbon cable in place.
      • Carefully pull the ribbon cable out, removing the camera from the motherboard.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team 7-1, Cheng Spring 2016 Membro de USF Tampa, Team 7-1, Cheng Spring 2016
USFT-CHENG-S16S7G1
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 38
Ao todo: 525
