Ir para o conteúdo principal
NeuTab Air7 Speaker Replacement
O que você precisa
  1. NeuTab Air7 Speaker Replacement, Back Cover: passo 1, imagem 1 %32 NeuTab Air7 Speaker Replacement, Back Cover: passo 1, imagem 2 %32 NeuTab Air7 Speaker Replacement, Back Cover: passo 1, imagem 3 %32
    • Ensure your device is powered off before you begin.
    • Use the opening tool to gently pry the back cover off of the tablet, running it along the perimeter of the device.
  2. NeuTab Air7 Speaker Replacement, Speaker: passo 2, imagem 1 %32 NeuTab Air7 Speaker Replacement, Speaker: passo 2, imagem 2 %32
    • The following instructions require soldiering, which can risk burn injuries as well as component damage for those novice in the skill. Tread with caution.
    • For a guide on how to solder, click here.
    • De-solder the red and black wire ends that connect the speaker to the motherboard.
  3. NeuTab Air7 Speaker Replacement: passo 3, imagem 1 %32 NeuTab Air7 Speaker Replacement: passo 3, imagem 2 %32 NeuTab Air7 Speaker Replacement: passo 3, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove the two 0.8 mm screws holding the cover of the speaker in place.
    • Remove the cover and the speaker.
Conclusão
Jason Soares
Membro desde: 10/29/23
532 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2023 Membro de UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 102
