Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
Unscrew the four 11.8 mm T-8 torx screws from the bottom of the router.
Lift the bottom casing straight up from the router.
Remove the clear plastic casing by lifting it straight up from the router.
Separate the motherboard from the top shell by lifting it straight up from the router.
Refer to this link for proper de-soldering and soldering techniques.
Peel off the yellow tape holding the wires.
Set the tape aside on a clean surface so that it can be reused.
Locate the clips that hold the antenna onto the router.
Pull out the antenna as well as the connected wire.
3 outras pessoas executaram este guia.
