Ir para o conteúdo principal
Netgear Arlo 2 Camera HD Security System Case Replacement
O que você precisa
    1. Netgear Arlo 2 Camera HD Security System Case Replacement, Case: passo 1, imagem 1 %32 Netgear Arlo 2 Camera HD Security System Case Replacement, Case: passo 1, imagem 2 %32 Netgear Arlo 2 Camera HD Security System Case Replacement, Case: passo 1, imagem 3 %32
      • Unscrew the two 3.0 mm Phillips #00 screws on the bottom of the camera.
      • Open the battery compartment on the bottom by pushing the switch marked in orange to the side and pushing the bottom of the camera back, sliding it open.
      Pergunte ao FixBot
      Comentar
    2. Netgear Arlo 2 Camera HD Security System Case Replacement: passo 2, imagem 1 %32 Netgear Arlo 2 Camera HD Security System Case Replacement: passo 2, imagem 2 %32
      • Remove the bottom piece of the case over the battery compartment by placing a plastic opening tool underneath the edge of the case and prying it up.
      • Unscrew the four 3.0 mm Phillips #00 screws on the outside of the battery pocket.
      Pergunte ao FixBot
      Comentar
    3. Netgear Arlo 2 Camera HD Security System Case Replacement: passo 3, imagem 1 %32 Netgear Arlo 2 Camera HD Security System Case Replacement: passo 3, imagem 2 %32
      • When facing the camera lens, the left panel of the case will be removed first (more steps are needed for the right panel).
      • Place the plastic opening tool between the two pieces of the case and pry them apart from the bottom.
      • Gently pull the side of the case off as it comes loose.
      Pergunte ao FixBot
      Comentar
    4. Netgear Arlo 2 Camera HD Security System Case Replacement: passo 4, imagem 1 %32 Netgear Arlo 2 Camera HD Security System Case Replacement: passo 4, imagem 2 %32
      • Unscrew the smaller 3.0 mm Phillips #00 screw in the center on the back of the device.
      • Flip the camera over and unscrew the center 3.0 mm Phillips #00 screw above the SYNC button.
      Pergunte ao FixBot
      Comentar
    5. Netgear Arlo 2 Camera HD Security System Case Replacement: passo 5, imagem 1 %32 Netgear Arlo 2 Camera HD Security System Case Replacement: passo 5, imagem 2 %32
      • Using the plastic opening tool, gently pry the right panel from the device.
      • Replace either side of the plastic case as needed.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
UMass Dartmouth, Team S2-G4, Peak Fall 2018 Membro de UMass Dartmouth, Team S2-G4, Peak Fall 2018
UMASSD-PEAK-F18S2G4
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 16
Últimos 30 dias: 32
Ao todo: 2,122
