Ir para o conteúdo principal
Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor Replacement
O que você precisa
  1. Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Removal from Wall: passo 1, imagem 1 %32 Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Removal from Wall: passo 1, imagem 2 %32
    • Grasp the display's metal outer ring with your fingers and pull directly away from the wall.
    Pergunte ao FixBot
    Comentar
  2. Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Open Display: passo 2, imagem 1 %32
    • Turn the display over.
    • Remove the four 6 mm screws from the back of the display using a Phillips #0 screwdriver.
    Pergunte ao FixBot
    Comentar
  3. Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Remove the back of the display: passo 3, imagem 1 %32 Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Remove the back of the display: passo 3, imagem 2 %32
    • Pinch the gray 20-pin connector with your fingers and pull directly away from the display.
    • Do NOT pull too far as there is a ribbon on the back panel connecting the 20-pin connector to the display.
    Pergunte ao FixBot
    Comentar
  4. Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Disconnect the base connection ribbon cable.: passo 4, imagem 1 %32 Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Disconnect the base connection ribbon cable.: passo 4, imagem 2 %32 Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Disconnect the base connection ribbon cable.: passo 4, imagem 3 %32
    • Locate the blue pull tab at the end of the ribbon which says, "1. Pull".
    • Grasp the tab with your fingers and pull directly away from the motherboard.
    Pergunte ao FixBot
    Comentar
  5. Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Lift battery from the base: passo 5, imagem 1 %32 Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Lift battery from the base: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Locate the blue tab which says, "2. Pull".
    • Use tweezers to pull the battery up and away from the display.
    • Do NOT pull too far, as the battery is still connected to the motherboard and must be unplugged.
    Pergunte ao FixBot
    Comentar
  6. Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Disconnect the battery from the motherboard: passo 6, imagem 1 %32 Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Disconnect the battery from the motherboard: passo 6, imagem 2 %32
    • Locate the blue tab which says "3 unplug".
    • Grasp the battery with your fingers. Pull gently directly away from the display to unplug the battery from the motherboard.
    Pergunte ao FixBot
    Comentar
  7. Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Remove battery from the display: passo 7, imagem 1 %32 Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Remove battery from the display: passo 7, imagem 2 %32 Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Remove battery from the display: passo 7, imagem 3 %32
    • Grasp the battery with your fingers and pull directly away from motherboard to separate the battery from the display.
    Pergunte ao FixBot
    Comentar
  8. Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Locate auto-away sensor: passo 8, imagem 1 %32
    • Locate the auto-away sensor.
    Pergunte ao FixBot
    Comentar
  9. Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Remove screws: passo 9, imagem 1 %32 Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Remove screws: passo 9, imagem 2 %32
    • Remove the four 3mm screws with a #0 Phillips screwdriver.
    • Remove the one 4mm screw located at the edge of the auto-away sensor. Use a #0 Phillips screwdriver.
    Pergunte ao FixBot
    Comentar
  10. Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Remove auto-away sensor: passo 10, imagem 1 %32 Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Remove auto-away sensor: passo 10, imagem 2 %32 Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Remove auto-away sensor: passo 10, imagem 3 %32
    • Lift the auto-away sensor from motherboard using tweezers.
    • Peel the copper foil gently from the EMI shield.
    Pergunte ao FixBot
    Comentar
  11. Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Remove screw from motherboard: passo 11, imagem 1 %32
    • Remove the 4 mm screw from the motherboard using a #0 Phillips screwdriver.
    Pergunte ao FixBot
    Comentar
  12. Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Removal of EMI Shield: passo 12, imagem 1 %32 Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Removal of EMI Shield: passo 12, imagem 2 %32
    • Remove the EMI shield from the motherboard using a plastic opening tool.
    Pergunte ao FixBot
    Comentar
  13. Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Disconnect the LCD ribbon: passo 13, imagem 1 %32 Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Disconnect the LCD ribbon: passo 13, imagem 2 %32
    • Unsnap the LCD ribbon from the motherboard gently using tweezers.
    Pergunte ao FixBot
    Comentar
  14. Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Disconnect the motherboard from the display: passo 14, imagem 1 %32 Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Disconnect the motherboard from the display: passo 14, imagem 2 %32 Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Disconnect the motherboard from the display: passo 14, imagem 3 %32
    • Locate the black tabs that hold the display to the motherboard.
    • Push the black tabs gently away from the motherboard using the plastic opening tools.
    Pergunte ao FixBot
    Comentar
  15. Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Separate the motherboard and the display: passo 15, imagem 1 %32 Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Separate the motherboard and the display: passo 15, imagem 2 %32
    • Pull the face display gently away from the motherboard.
    Pergunte ao FixBot
    Comentar
  16. Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Separate motherboard from steel ring: passo 16, imagem 1 %32
    • Using one hand to hold the steel ring, carefully lift the motherboard out of the ring using the other hand.
    Pergunte ao FixBot
    Comentar
  17. Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Removal of optical finger: passo 17, imagem 1 %32 Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Removal of optical finger: passo 17, imagem 2 %32 Nest Learning Thermostat 2nd Generation Optical Finger Motion Sensor  Replacement, Removal of optical finger: passo 17, imagem 3 %32
    • Locate the optical sensor, a small board attached at 90 degrees from the side of the motherboard.
    • Using the tweezers, grasp the small green piece of exposed board on the sensor, and pull directly away from the side of the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 11-5, Blackwell Fall 2014 Membro de USF Tampa, Team 11-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G5
5 Membros
Autoria de 12 guias
11Comentários do guia
Where can I get the sensor?
tyjustice - Responder Compartilhar
I second this, for the life of me, I can't find it. Just data specs and how most of the electronics retailers online says it obsolete, specially since Avago got absorbed by Broadcom.
Luis A. Cornejo - Responder Compartilhar
This is helpful up to the point where I need to know where to get the sensor. Where do I get the sensor?
Art Adams - Responder Compartilhar
Any update where to get a new sensor? I just received a device from a friend and it needs to be fixed.
Steven D'Ambrozio - Responder Compartilhar
The easier path would be to install a rotary encoder, and call it a day. If you do find the sensor, you have to code basically a driver for it and print your own pattern.
ic3balandran - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 38
Ao todo: 6,475
