Ir para o conteúdo principal
Nest Hello Battery Replacement
O que você precisa
  1. Nest Hello Battery Replacement, Casing and Faceplate: passo 1, imagem 1 %32
    • Insert the pick between the black faceplate and white casing of the Nest Hello.
    • Pry the faceplate away from the device with the opening pick.
    • If you have not opened the Nest Hello before, there will be a protective foam mesh that is glued to the plastic covering and the inside of the mesh, use a pick to cut through the mesh as much as possible.
    • Completely remove the faceplate from the device, do not be afraid to pull hard.
  2. Nest Hello Battery Replacement: passo 2, imagem 1 %32 Nest Hello Battery Replacement: passo 2, imagem 2 %32
    • Peel back the cover stickers and use the Phillips #000 screwdriver to remove the four screws.
  3. Nest Hello Battery Replacement: passo 3, imagem 1 %32 Nest Hello Battery Replacement: passo 3, imagem 2 %32 Nest Hello Battery Replacement: passo 3, imagem 3 %32
    • Insert opening pick between the white casing and the black internal circuitry and pry it out.
    • There is a ribbon cable connecting the white casing to the circuit boards. Be careful not to tear out the cable while separating the casing from the circuit boards.
  4. Nest Hello Battery Replacement, Battery: passo 4, imagem 1 %32 Nest Hello Battery Replacement, Battery: passo 4, imagem 2 %32 Nest Hello Battery Replacement, Battery: passo 4, imagem 3 %32
    • Once the back casing is removed, disconnect the battery cable and remove the battery from the device.
Conclusão
36 outras pessoas executaram este guia.
47Comentários do guia
Any recommendations as to where we can find a replacement battery? Model #, specs?
Patrick Ouellet - Responder
Flujoy 280mAh/3.7V Replacement Battery for Nest C1241290 Vido Doorbell Wired NC5100US Hello 1ICP7/17/26
About $16 from Amazon
Joel Lundi -
Battery and o-ring part source?
Ryan - Responder
What is the replacement battery?
Leon Sparrow - Responder
Search Amazon for the following and you should find several choices:
Nest Hello NC5100US C1241290 Video Doorbell Wired
JOHN ZUCKERMAN -
Comentar
Visualizações:
Últimas 24 horas: 60
Últimos 7 dias: 441
Últimos 30 dias: 2,111
Ao todo: 79,828
