Introdução
This guide is used to replace the LEDs inside the Nest Dropcam Pro in case they are broken or blown. Make sure the device is unplugged before opening.
O que você precisa
Press in the mounting clips on each side of the case to remove the camera from the mount.
Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
Quase terminado!
Conclusão
