Ir para o conteúdo principal
Nest Cam Motherboard Replacement
O que você precisa
  1. Nest Cam Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Remove the four 6 mm screws from the back panel with the JIS 000 screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Motherboard Replacement: passo 2, imagem 1 %32 Nest Cam Motherboard Replacement: passo 2, imagem 2 %32 Nest Cam Motherboard Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
  3. Nest Cam Motherboard Replacement: passo 3, imagem 1 %32 Nest Cam Motherboard Replacement: passo 3, imagem 2 %32
    • Remove the two 4 mm screws with the JIS 000 screwdriver from the center.
    • Disconnect the black Wi-Fi cable from the motherboard with the tweezers.
  4. Nest Cam Motherboard Replacement: passo 4, imagem 1 %32 Nest Cam Motherboard Replacement: passo 4, imagem 2 %32 Nest Cam Motherboard Replacement: passo 4, imagem 3 %32
    • Use a plastic spudger to lift the motherboard slightly up to expose and disconnect the white cable and the yellow/white IR cable with tweezers.
    • Then use the spudger or a finger to lift the motherboard completely up and off.
    • When installing the new motherboard ensure that all wires are reconnected before securing.
Conclusão
5 outras pessoas executaram este guia.
Khiry Jones
Membro desde: 02/29/16
159 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-1, Leahy Spring 2016 Membro de USF Tampa, Team 1-1, Leahy Spring 2016
USFT-LEAHY-S16S1G1
Membros da 7
Autoria de 10 guias
4 comentários
where can I get a MoBo for my drop cam?
mikelebp1 - Responder
where can i find a motherboard replacement?
Steve - Responder
I have a Nest Outdoor IQ Camera. The Camera is Dead. Would love to Replace the Motherboard. Where can I get one ???
pmwenc@aol.com - Responder
same here, no where to be found online
chantalder - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 19
Últimos 30 dias: 41
Duração total: 24,690
