Introdução
If your Nest Cam IQ has lost clear viability, you most likely have a cracked lens, which Requires replacement.
A functional lens provides a clear view. If you notice poor quality or lines when pulling up Nest Cam IQ recordings, consider changing out your lens.
O que você precisa
To soften the adhesive holding the camera together, heat up the edges of the glass lens using a heated iOpener on the device. Alternatively, you can use a heat gun to loosen the adhesive.
Leave the Opener on the glass lens for two minutes.
Uma outra pessoa concluiu este guia.
