Ir para o conteúdo principal
Nest Cam IQ Camera Replacement
O que você precisa
  1. Nest Cam IQ Camera Replacement, Camera: passo 1, imagem 1 %32
    • To soften the adhesive holding the camera together, heat up the edges of the glass lens using a heated iOpener on the device. Alternatively, you can use a heat gun to loosen the adhesive.
    • Leave the iOpener on the glass lens for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
  2. Nest Cam IQ Camera Replacement: passo 2, imagem 1 %32
    • Use an opening tool to split apart the glass lens from the body.
    • Be careful to not break the glass when prying from the body.
  3. Nest Cam IQ Camera Replacement: passo 3, imagem 1 %32
    • Place a suction cup on the glass lens that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the glass lens and the body.
    • Pull off the glass lens using the suction cup.
  4. Nest Cam IQ Camera Replacement: passo 4, imagem 1 %32 Nest Cam IQ Camera Replacement: passo 4, imagem 2 %32
    • Carefully disconnect the flat black ribbon cable connecting the metal plate to the LED.
    • Remove the metal plate.
  5. Nest Cam IQ Camera Replacement: passo 5, imagem 1 %32 Nest Cam IQ Camera Replacement: passo 5, imagem 2 %32
    • Remove the five 9 mm TR6 Torx screws from the LED cover.
    • Pull off the LED cover.
    • As you remove the LED cover, be careful not to tear the flat black ribbon connecting the LED to the motherboard.
  6. Nest Cam IQ Camera Replacement: passo 6, imagem 1 %32 Nest Cam IQ Camera Replacement: passo 6, imagem 2 %32 Nest Cam IQ Camera Replacement: passo 6, imagem 3 %32
    • Carefully disconnect the flat black ribbon cable connecting the LED to the motherboard.
    • Remove the LED cover.
  7. Nest Cam IQ Camera Replacement: passo 7, imagem 1 %32
    • Remove the two 7 mm TR6 Torx screws securing the camera.
    • Carefully pull out the camera.
    • As you remove the camera, be careful not to tear the flat black ribbon connecting the camera to the motherboard.
  8. Nest Cam IQ Camera Replacement: passo 8, imagem 1 %32 Nest Cam IQ Camera Replacement: passo 8, imagem 2 %32
    • Carefully disconnect the flat black ribbon cable connecting the camera to the motherboard.
    • Remove the camera.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 25
Duração total: 171
