Ir para o conteúdo principal
Nerf Vortex Vigilon Loading Spring Replacement
O que você precisa
    1. Nerf Vortex Vigilon Loading Spring Replacement, Removing the slide screws: passo 1, imagem 1 %32
      • The two slide pieces hold the orange sight in place. Expect that the sight will come off when you remove the slide pieces.
      • Using a screwdriver, carefully unscrew the three #00 1 cm Phillips screws holding the two slide pieces together.
      • Both sides of the slide will come off when the screws are removed.
      Pergunte ao FixBot
      Comentar
    2. Nerf Vortex Vigilon Loading Spring Replacement, Removing the slide pieces: passo 2, imagem 1 %32
      • Lift both slide pieces off of the gun.
      Pergunte ao FixBot
      Comentar
    1. Nerf Vortex Vigilon Loading Spring Replacement, Removing the outer screws: passo 3, imagem 1 %32 Nerf Vortex Vigilon Loading Spring Replacement, Removing the outer screws: passo 3, imagem 2 %32
      • Remove the twelve #00 1 cm Phillips screws.
      • Because the holes for the screws are deeper than the screw size, some of the screws may not come out even after you have completely unscrewed them. They will come out when you take off the outside cover in the next step, which is okay.
      • Rotate the gun so that the front is facing you to remove the final screw.
      Pergunte ao FixBot
      Comentar
    2. Nerf Vortex Vigilon Loading Spring Replacement, Removing the outside cover: passo 4, imagem 1 %32
      • When removing the cover, the clip attachment and the spring will likely fall out of the gun.
      • Lift the outside cover off of the gun. Only the side where you removed the screws will come off.
      • The magazine will slide down automatically as you remove the cover.
      Pergunte ao FixBot
      Comentar
    1. Nerf Vortex Vigilon Loading Spring Replacement, Removing the spring: passo 5, imagem 1 %32 Nerf Vortex Vigilon Loading Spring Replacement, Removing the spring: passo 5, imagem 2 %32
      • Lift the spring out towards you.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Cara Pew
Membro desde: 09/29/14
932 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 13-6, Forte Fall 2014 Membro de Cal Poly, Team 13-6, Forte Fall 2014
CPSU-FORTE-F14S13G6
5 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 37
Ao todo: 1,934
