Introdução
With this guide, you will be able to replace a clip attachment that is worn or cracked. All you will need is a screwdriver.
O que você precisa
Using a screwdriver, carefully unscrew the three #00 1 cm Phillips screws holding the two slide pieces together.
Remove the twelve #00 1 cm Phillips screws.
Rotate the gun so that the front is facing you to remove the final screw.
Lift the outside cover off of the gun. Only the side where you removed the screws will come off.
At the top left area of the gun, lift the clip towards you, and it will easily slide out.
Uma outra pessoa concluiu este guia.
