Ir para o conteúdo principal
Nerf Recon CS-6 Main Spring Replacement
O que você precisa
    1. Nerf Recon CS-6 Main Spring Replacement, Remove Magazine: passo 1, imagem 1 %32
      • Skip this step if magazine is already removed.
      • Pull slide back.
      • Pull backwards on release buttons and slide magazine out.
      • Push slide back forward and pull trigger.
      Pergunte ao FixBot
      Comentar
    2. Nerf Recon CS-6 Main Spring Replacement, Remove Visible Screws: passo 2, imagem 1 %32
      • Use the Phillips #0 Screwdriver to remove these 9 screws.
      • All screws marked in red are 9.6 mm Phillips #0 screws.
      • Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
      Pergunte ao FixBot
      Comentar
    3. Nerf Recon CS-6 Main Spring Replacement, Remove Hidden Screws: passo 3, imagem 1 %32 Nerf Recon CS-6 Main Spring Replacement, Remove Hidden Screws: passo 3, imagem 2 %32
      • Pull slide back to reveal more screws.
      • Remove these 2 screws.
      • Push slide forward.
      • Pull trigger to release compression of the main spring.
      • Screws are 9.6 mm Phillips #0.
      • Pulling the trigger will keep spring from launching out of the gun when the two halves are separated.
      Pergunte ao FixBot
      Comentar
    4. Nerf Recon CS-6 Main Spring Replacement, Remove Plunger Cap: passo 4, imagem 1 %32
      • Remove the screws on the plunger cap.
      • Tug the plunger cap off.
      Pergunte ao FixBot
      Comentar
    5. Nerf Recon CS-6 Main Spring Replacement, Remove Slide Screws: passo 5, imagem 1 %32
      • Remove the 2 screws on the slide.
      • Hold the two halves of the gun together to prevent any springs from launching out.
      Pergunte ao FixBot
      Comentar
    6. Nerf Recon CS-6 Main Spring Replacement, Split the Gun in Half: passo 6, imagem 1 %32 Nerf Recon CS-6 Main Spring Replacement, Split the Gun in Half: passo 6, imagem 2 %32
      • Pull the gun apart at the middle seam.
      • Watch for any springs that might launch out.
      Pergunte ao FixBot
      Comentar
    1. Nerf Recon CS-6 Main Spring Replacement, Remove Spring: passo 7, imagem 1 %32 Nerf Recon CS-6 Main Spring Replacement, Remove Spring: passo 7, imagem 2 %32
      • Pull the spring out the back of the gun.
      Pergunte ao FixBot
      Comentar
Conclusão
8 outras pessoas executaram este guia.
Asad Qureshi
Membro desde: 10/22/14
595 Reputação
Autoria de 3 guias
Equipe
Baylor, Team 8-14, Williams Fall 2014 Membro de Baylor, Team 8-14, Williams Fall 2014
BU-WILLIAMS-F14S8G14
3 Membros
Autoria de 6 guias
1Comentário do guia
Where can you buy replacement springs from?
Tom Hallam - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 48
Ao todo: 6,614
