Ir para o conteúdo principal
Nerf N-Strike Maverick Catch Spring Replacement
O que você precisa
    1. Nerf N-Strike Maverick Catch Spring Replacement, Use the Teardown Guide to Open the Gun: passo 1, imagem 1 %32
      Pergunte ao FixBot
      Comentar
    2. Nerf N-Strike Maverick Catch Spring Replacement, Remove Large Spring: passo 2, imagem 1 %32
      • Remove the larger spring from the catch mechanism.
      Pergunte ao FixBot
      Comentar
    3. Nerf N-Strike Maverick Catch Spring Replacement, Remove the Catch Mechanism & Spring: passo 3, imagem 1 %32
      • Remove the catch mechanism and spring by gently lifting it straight up and off the metal pin that holds it.
      • The catch spring has a tendency to bounce away when removed.
      Pergunte ao FixBot
      Comentar
    4. Nerf N-Strike Maverick Catch Spring Replacement, Replace the Catch Spring: passo 4, imagem 1 %32
      • After removing the old catch spring, place the new catch spring back on the tip of the catch mechanism.
      • If you are unable to find an exact replacement, one may be fashioned out of a pen spring.
      Pergunte ao FixBot
      Comentar
    5. Nerf N-Strike Maverick Catch Spring Replacement, Putting the Catch Mechanism Back: passo 5, imagem 1 %32
      • Carefully replace the catch mechanism so that it is seated in the grooves and over the metal pin.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Equipe
1Comentário do guia
do you have a spare catch spring the whole catch mechanism and spring
cowboybebop6968 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 22
Últimos 30 dias: 67
Ao todo: 8,341
