Ir para o conteúdo principal
Nerf N-Strike Firestrike Laser Trigger Replacement
O que você precisa
    1. Nerf N-Strike Firestrike Laser Trigger Replacement, Remove battery cover: passo 1, imagem 1 %32
      • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
      Pergunte ao FixBot
      Comentar
    2. Nerf N-Strike Firestrike Laser Trigger Replacement: passo 2, imagem 1 %32 Nerf N-Strike Firestrike Laser Trigger Replacement: passo 2, imagem 2 %32
      • Slide out the two AAA batteries using your fingers.
      Pergunte ao FixBot
      Comentar
    1. Nerf N-Strike Firestrike Laser Trigger Replacement, Blaster Casing: passo 3, imagem 1 %32
      • Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Nerf N-Strike Firestrike Laser Trigger Replacement: passo 4, imagem 1 %32 Nerf N-Strike Firestrike Laser Trigger Replacement: passo 4, imagem 2 %32
      • Slowly pull apart the blaster casing, starting at the battery location.
      • Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
      Pergunte ao FixBot
      Comentar
    3. Nerf N-Strike Firestrike Laser Trigger Replacement: passo 5, imagem 1 %32 Nerf N-Strike Firestrike Laser Trigger Replacement: passo 5, imagem 2 %32
      • For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box.
      • For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
      • For reassembly, note the location of the springs as highlighted in the second photo.
      Pergunte ao FixBot
      Comentar
    1. Nerf N-Strike Firestrike Laser Trigger Replacement, Laser Trigger: passo 6, imagem 1 %32 Nerf N-Strike Firestrike Laser Trigger Replacement, Laser Trigger: passo 6, imagem 2 %32
      • Remove the laser trigger by grabbing the trigger with your fingers and pulling it up and out.
      Pergunte ao FixBot
      Comentar
Conclusão
Jong Wan Kim
Membro desde: 04/22/15
488 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 15-6, Amido Spring 2015 Membro de Cal Poly, Team 15-6, Amido Spring 2015
CPSU-AMIDO-S15S15G6
3 Membros
Autoria de 16 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 32
Ao todo: 2,187
