Ir para o conteúdo principal
Nerf N-Strike Elite Retaliator Trigger Spring Replacement
O que você precisa
    1. Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Case Disassembly: passo 1, imagem 1 %32
      • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
      Pergunte ao FixBot
      Comentar
    2. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: passo 2, imagem 1 %32
      • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
      Pergunte ao FixBot
      Comentar
    3. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: passo 3, imagem 1 %32
      • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
      Pergunte ao FixBot
      Comentar
    4. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: passo 4, imagem 1 %32 Nerf N-Strike Elite Retaliator Trigger Spring Replacement: passo 4, imagem 2 %32
      • Remove the stock attachment point by removing the two 8mm Phillips head screws.
      Pergunte ao FixBot
      Comentar
    5. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: passo 5, imagem 1 %32 Nerf N-Strike Elite Retaliator Trigger Spring Replacement: passo 5, imagem 2 %32
      • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
      • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
      • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
      Pergunte ao FixBot
      Comentar
    1. Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Trigger Spring: passo 6, imagem 1 %32 Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Trigger Spring: passo 6, imagem 2 %32 Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Trigger Spring: passo 6, imagem 3 %32
      • Carefully pull the orange trigger upward and backward to remove it from the blaster.
      • This component is under spring pressure. Wear appropriate personal protective equipment to shield your eyes.
      • Remove the spring from the rear of the trigger.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
ericharman
Membro desde: 03/02/16
1.440 Reputação
Autoria de 5 guias
1Comentário do guia
ok, taken the spring out. now what?
Kelvin Mead - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 24
Ao todo: 10,130
