Introdução
This easy three step guide will help you find and replace the battery.
O que você precisa
Using the JIS #1 screwdriver, loosen (without removing) the screw, holding the battery compartment door in place.
Lift the door off the battery compartment.
Remove and replace the batteries, properly discarding the used batteries.
Uma outra pessoa concluiu este guia.
