Ir para o conteúdo principal
Neo3Do Wire Replacement
O que você precisa
  1. Neo3Do Wire Replacement, Back Panel: passo 1, imagem 1 %32 Neo3Do Wire Replacement, Back Panel: passo 1, imagem 2 %32 Neo3Do Wire Replacement, Back Panel: passo 1, imagem 3 %32
    • Turn the Neo3DO face down so that the logo is facing toward you.
    • Insert the plastic opening tool between the metal frame and the plastic back panel, as shown.
    Pergunte ao FixBot
    Comentar
  2. Neo3Do Wire Replacement: passo 2, imagem 1 %32 Neo3Do Wire Replacement: passo 2, imagem 2 %32
    • Gently pry the back panel upwards.
    • Ensure the tool does not slip into the device and damage the internals.
    Pergunte ao FixBot
    Comentar
  3. Neo3Do Wire Replacement: passo 3, imagem 1 %32 Neo3Do Wire Replacement: passo 3, imagem 2 %32
    • Once the back panel has been pried away from the bottom and sides of the Neo3DO, lift the back panel up and away from the tablet.
    Pergunte ao FixBot
    Comentar
  4. Neo3Do Wire Replacement: passo 4, imagem 1 %32
    • When replacing the back panel, place the top edge of the back panel against the top edge of the Neo3DO, as shown.
    • The top edge of the device is the edge closest to the camera. The top of the back panel is the side with the hole for the camera.
    Pergunte ao FixBot
    Comentar
  5. Neo3Do Wire Replacement, Wire: passo 5, imagem 1 %32 Neo3Do Wire Replacement, Wire: passo 5, imagem 2 %32 Neo3Do Wire Replacement, Wire: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Starting with an open back panel, take your tweezers and use them to pull back the black tabs on the connector.
    Pergunte ao FixBot
    Comentar
  6. Neo3Do Wire Replacement: passo 6, imagem 1 %32
    • Pull the wire completely from the socket.
    • Check the metallic parts for signs of damage or corrosion. If either exists, you might need to replace the battery entirely.
    Pergunte ao FixBot
    Comentar
  7. Neo3Do Wire Replacement: passo 7, imagem 1 %32
    • Re-insert the wire into the socket.
    Pergunte ao FixBot
    Comentar
  8. Neo3Do Wire Replacement: passo 8, imagem 1 %32 Neo3Do Wire Replacement: passo 8, imagem 2 %32 Neo3Do Wire Replacement: passo 8, imagem 3 %32
    • Using the tweezers, push the black tabs back in.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team 14-3, Eyestone Fall 2016 Membro de USF Tampa, Team 14-3, Eyestone Fall 2016
USFT-EYESTONE-F16S14G3
3 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 28
Ao todo: 403
