Ir para o conteúdo principal
Neato Botvac D75 Battery Replacement
O que você precisa
    1. Neato Botvac D75 Battery Replacement, Battery: passo 1, imagem 1 %32 Neato Botvac D75 Battery Replacement, Battery: passo 1, imagem 2 %32 Neato Botvac D75 Battery Replacement, Battery: passo 1, imagem 3 %32
      • Use Phillips #1 screwdriver to unscrew the two bottom cover screws
      • Be careful, the screws are self-retained on the cover itself and does not come off the battery cover.
      Pergunte ao FixBot
      Comentar
    2. Neato Botvac D75 Battery Replacement: passo 2, imagem 1 %32 Neato Botvac D75 Battery Replacement: passo 2, imagem 2 %32 Neato Botvac D75 Battery Replacement: passo 2, imagem 3 %32
      • Lift battery cover out.
      Pergunte ao FixBot
      Comentar
    3. Neato Botvac D75 Battery Replacement: passo 3, imagem 1 %32 Neato Botvac D75 Battery Replacement: passo 3, imagem 2 %32 Neato Botvac D75 Battery Replacement: passo 3, imagem 3 %32
      • Be careful when taking out the battery. Do not pull on the wires or battery trying to get the connector out.
      • The cord has prongs on it that are a little difficult to get out. Use a flathead screwdriver to press the release tab on the connector to remove it.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Juan Cornejo
Membro desde: 02/15/17
606 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S6-G5, Lacy Spring 2017 Membro de USF Tampa, Team S6-G5, Lacy Spring 2017
USFT-LACY-S17S6G5
4 Membros
Autoria de 15 guias
1Comentário do guia
Thanks for the tuto.
an additionnal info when having a battery issue, is to the reset to new battery. enter the menu, then help, and chose new battery.
it seems the neato system is set for planned obsolescence… unfortunatly for customers….
so I did it because battery stayed empty while plugged and switch found ok . And new my botvac is ok, like new!!
Nom - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 50
Ao todo: 2,998
