Ir para o conteúdo principal
Nail Clipper Reassembly
  1. Nail Clipper Reassembly, Nail Clipper Reassembly: passo 1, imagem 1 %32 Nail Clipper Reassembly, Nail Clipper Reassembly: passo 1, imagem 2 %32 Nail Clipper Reassembly, Nail Clipper Reassembly: passo 1, imagem 3 %32
    • Insert the rod through the bottom hole of the clipper body, and continue through the top hole.
    • The side of the rod with the notch should be inserted first.
    • Note: The top of the clipper body will often have a pick/file attached to it. If no pick/file is present, either side can serve as the top or the bottom.
    Pergunte ao FixBot
    Comentar
  2. Nail Clipper Reassembly: passo 2, imagem 1 %32
    • Compress the body of the clippers to reveal the notch.
    Pergunte ao FixBot
    Comentar
  3. Nail Clipper Reassembly: passo 3, imagem 1 %32
    • Rotate the rod until the notch opening faces away from the body.
    • This allows for easier completion of the following step.
    Pergunte ao FixBot
    Comentar
  4. Nail Clipper Reassembly: passo 4, imagem 1 %32 Nail Clipper Reassembly: passo 4, imagem 2 %32 Nail Clipper Reassembly: passo 4, imagem 3 %32
    • Place the hole of the lever into the revealed rod notch.
    • Release the compressed nail clipper body to lock the lever into place.
    • Note: Position of the lever does not matter at this point.
    Pergunte ao FixBot
    Comentar
  5. Nail Clipper Reassembly: passo 5, imagem 1 %32 Nail Clipper Reassembly: passo 5, imagem 2 %32 Nail Clipper Reassembly: passo 5, imagem 3 %32
    • Swivel the lever into its normal position, and test the nail clippers' functionality.
    Pergunte ao FixBot
    Comentar
Conclusão
If you follow these steps, your nail clippers should be back to working order.
96 outras pessoas executaram este guia.
Robert Weber
Membro desde: 04/09/15
2.149 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 30-5, Green Spring 2015 Membro de Cal Poly, Team 30-5, Green Spring 2015
CPSU-GREEN-S15S30G5
5 Membros
Autoria de 33 guias
33Comentários do guia
Thank you so much ! My fingers are arthritic and I was frustrated until I found your instructions.
marvin - Responder Compartilhar
Thank you. Knew it was simple! Love this website.
jonathanl.aguiar - Responder Compartilhar
This is the dumbest “repair guide” I have ever seen. It is not a repair, because they are not broken, it’s a re-assembly.
Albert E - Responder Compartilhar
That's why it says reassembly 🤨
Blake Jordan-Borns - Responder Compartilhar
Thank you so much!!!! I could only find one pair in my house and was feeling desperate. This is the best guide to repair and I’m glad you posted under broken nail clippers because that’s what I considered mine to be and how I looked it up.
Tanya Bishop - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 58
Últimos 7 dias: 371
Últimos 30 dias: 1,719
Ao todo: 157,707
