Ir para o conteúdo principal
Nabi Jr Motherboard Replacement
O que você precisa
    1. Nabi Jr Motherboard Replacement, Rear Case: passo 1, imagem 1 %32
      • Remove the red rubber case from the device. This should come off with ease.
      Pergunte ao FixBot
      Comentar
    2. Nabi Jr Motherboard Replacement: passo 2, imagem 1 %32
      • Turn the device so the screen is facing away from you.
      • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
      Pergunte ao FixBot
      Comentar
    3. Nabi Jr Motherboard Replacement: passo 3, imagem 1 %32
      • Remove the device casing using a small plastic pry bar.
      • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
      Pergunte ao FixBot
      Comentar
    4. Nabi Jr Motherboard Replacement: passo 4, imagem 1 %32
      • After loosening the back cover, remove it from the device so you can get at the innards.
      Pergunte ao FixBot
      Comentar
    1. Nabi Jr Motherboard Replacement, Motherboard: passo 5, imagem 1 %32
      • Use the Philips #00 screwdriver to remove the 5 screws from the motherboard
      Pergunte ao FixBot
      Comentar
    2. Nabi Jr Motherboard Replacement: passo 6, imagem 1 %32
      • De-solder the grey wire from motherboard
      Pergunte ao FixBot
      Comentar
    3. Nabi Jr Motherboard Replacement: passo 7, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Use tweezers to peel off all yellow tape from the motherboard
      • Yellow tape is used in all locations where there is ribbon cable present.
      Pergunte ao FixBot
      Comentar
    4. Nabi Jr Motherboard Replacement: passo 8, imagem 1 %32 Nabi Jr Motherboard Replacement: passo 8, imagem 2 %32
      • Remove all three ribbon cables from the motherboard by lifting up the locking tabs.
      • Pull black locking tabs up in opposite direction of ribbon cable to remove.
      • Use tweezers to pull the ribbon cable out of the locking tab's slot
      Pergunte ao FixBot
      Comentar
    5. Nabi Jr Motherboard Replacement: passo 9, imagem 1 %32 Nabi Jr Motherboard Replacement: passo 9, imagem 2 %32
      • Lift motherboard to separate it the from the case shell.
      Pergunte ao FixBot
      Comentar
Conclusão
Kaila Joy
Membro desde: 03/24/15
86 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 16
Ao todo: 1,442
