Introdução
If your screen is cracked be careful when trying to pry off the screen. The broken shards of glass on the screen may cut you, so be extremely careful. The screen is glued onto the display with some type of adhesive, so it will take some time to get it off. This process would take a lot of time so be patient.Do not try to pry off the screen from only one corner or side since it is glass you will just shatter the whole screen.
O que você precisa
Take out the two black 4.5 mm screws with your Phillips # 1 screwdriver and remove the circuit board.
Once you create a space between the screen and the frame stick an i fixit pick in the crack to keep the crack open.
Keep inserting more picks every time you create some space, so eventually the screen will be completely separated from the frame.
Use the plastic opening tool to carefully remove the screen from the frame.
5 comentários
Where do you get parts for this thing tho
Any luck finding screen
Im looking for a screen too. Any luck on a referral?
