Ir para o conteúdo principal
Nabi 2 Heat Sink Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Nabi 2 Heat Sink Replacement, Open the device: passo 1, imagem 1 %32
    • Remove all the screws and place them on a magnet. This will keep them from rolling away and becoming lost.
    Pergunte ao FixBot
    Comentar
  2. Nabi 2 Heat Sink Replacement: passo 2, imagem 1 %32
    • Insert a flat-edge and attempt to gently pry the covers apart. If you pry them too roughly, they may crack and break. (DO NOT have a magnet near the tablet when you open it. This will destroy all files and programs on your tablet, making it useless.)
    Pergunte ao FixBot
    Comentar
  3. Nabi 2 Heat Sink Replacement, Look for Heat Sink: passo 3, imagem 1 %32
    • Check to see if there is a large piece of metal tape over the battery. This is the heat sink. Its purpose is to disburse the heat away from the battery and hard drive, cooling the tablet and keeping it from overheating.
    • If the piece of tape is not there, and the tablet will not turn on, the tablet most likely shorted out.
    Pergunte ao FixBot
    Comentar
    • If the piece of tape is missing, you will need to purchase the appropriate metal tape. This can be found online.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
lauryn
Membro desde: 11/13/14
215 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 20
Ao todo: 1,486
