Ir para o conteúdo principal
Nabi 2 Charging Port Replacement
O que você precisa
    1. Nabi 2 Charging Port Replacement, Nabi 2 Back Cover Removal: passo 1, imagem 1 %32 Nabi 2 Charging Port Replacement, Nabi 2 Back Cover Removal: passo 1, imagem 2 %32 Nabi 2 Charging Port Replacement, Nabi 2 Back Cover Removal: passo 1, imagem 3 %32
      • Remove the rubber bumper from the tablet.
      Pergunte ao FixBot
      Comentar
    2. Nabi 2 Charging Port Replacement: passo 2, imagem 1 %32 Nabi 2 Charging Port Replacement: passo 2, imagem 2 %32
      • With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
      Pergunte ao FixBot
      Comentar
    3. Nabi 2 Charging Port Replacement: passo 3, imagem 1 %32 Nabi 2 Charging Port Replacement: passo 3, imagem 2 %32 Nabi 2 Charging Port Replacement: passo 3, imagem 3 %32
      • Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
      • Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
      • Do not force the clips open, as they are fairly easy to break
      Pergunte ao FixBot
      Comentar
    1. Nabi 2 Charging Port Replacement, Screen: passo 4, imagem 1 %32 Nabi 2 Charging Port Replacement, Screen: passo 4, imagem 2 %32 Nabi 2 Charging Port Replacement, Screen: passo 4, imagem 3 %32
      • Lay the tablet down flat and remove the yellow tape from the ZIF connector on each side
      Pergunte ao FixBot
      Comentar
    2. Nabi 2 Charging Port Replacement: passo 5, imagem 1 %32 Nabi 2 Charging Port Replacement: passo 5, imagem 2 %32 Nabi 2 Charging Port Replacement: passo 5, imagem 3 %32
      • Using a spudger, slide the brown tab forward on each side of the connector
      • Slide until the connector is completely loose, then separate the screen from the bottom half of the tablet
      • If the screen is not working correctly, you will need to replace the entire display assembly
      Pergunte ao FixBot
      Comentar
    1. Nabi 2 Charging Port Replacement, Battery: passo 6, imagem 1 %32 Nabi 2 Charging Port Replacement, Battery: passo 6, imagem 2 %32 Nabi 2 Charging Port Replacement, Battery: passo 6, imagem 3 %32
      • Use the spudger to pop the battery out of place and set it aside.
      Pergunte ao FixBot
      Comentar
    2. Nabi 2 Charging Port Replacement: passo 7, imagem 1 %32 Nabi 2 Charging Port Replacement: passo 7, imagem 2 %32 Nabi 2 Charging Port Replacement: passo 7, imagem 3 %32
      • Desolder the battery connection and remove the battery completely
      • Note the color order for future replacemement
      Pergunte ao FixBot
      Comentar
    1. Nabi 2 Charging Port Replacement, Internal Speakers: passo 8, imagem 1 %32
      • Using the soldering iron, detach the speaker's wires from the circuit board.
      Pergunte ao FixBot
      Comentar
    2. Nabi 2 Charging Port Replacement: passo 9, imagem 1 %32 Nabi 2 Charging Port Replacement: passo 9, imagem 2 %32 Nabi 2 Charging Port Replacement: passo 9, imagem 3 %32
      • Using a Phillips PH 000 screwdriver, unscrew the two 3 mm Phillips #000 screws on each side of the speakers that hold the speakers in place.
      Pergunte ao FixBot
      Comentar
    3. Nabi 2 Charging Port Replacement: passo 10, imagem 1 %32
      • Once the screws have been removed, remove the speakers from the device.
      Pergunte ao FixBot
      Comentar
    1. Nabi 2 Charging Port Replacement, Motherboard: passo 11, imagem 1 %32 Nabi 2 Charging Port Replacement, Motherboard: passo 11, imagem 2 %32
      • Remove the seven 4 mm Phillips #000 screws with a PH#000 screwdriver
      Pergunte ao FixBot
      Comentar
    2. Nabi 2 Charging Port Replacement: passo 12, imagem 1 %32 Nabi 2 Charging Port Replacement: passo 12, imagem 2 %32 Nabi 2 Charging Port Replacement: passo 12, imagem 3 %32
      • Remove the tape that is attaching the motherboard to the plastic casing
      Pergunte ao FixBot
      Comentar
    3. Nabi 2 Charging Port Replacement: passo 13, imagem 1 %32 Nabi 2 Charging Port Replacement: passo 13, imagem 2 %32 Nabi 2 Charging Port Replacement: passo 13, imagem 3 %32
      • Remove the motherboard by lifting from the area indicated
      Pergunte ao FixBot
      Comentar
    1. Nabi 2 Charging Port Replacement, Charging Port: passo 14, imagem 1 %32 Nabi 2 Charging Port Replacement, Charging Port: passo 14, imagem 2 %32 Nabi 2 Charging Port Replacement, Charging Port: passo 14, imagem 3 %32
      • Using a soldering iron, desolder the charging port from the motherboard
      • Remove the charging port completely
      • If the glue does not completely detach from the board, try to heat it until the charging port can be removed
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
USF Tampa, Team 4-3, Lacy Spring 2016 Membro de USF Tampa, Team 4-3, Lacy Spring 2016
USFT-LACY-S16S4G3
4 Membros
Autoria de 14 guias
7Comentários do guia
I think you would be better to just through it away and get something else.
Brad Cobb - Responder Compartilhar
Naw they are still a handy fairly tough tablet for the kids shame about badly designed dc port I managed to find ports for it on ebay.
http://www.ebay.com/itm/dc-socket-port-j...
DotDotCom - Responder Compartilhar
send me a new nabi in the mail today
Deborah Cramer - Responder Compartilhar
A lot of unneeded work there. The power port is surface mount and and can be replaced without removing the PCB or anything else, but the back.
Donnie
Donnie - Responder Compartilhar
Do steps 1-3 above then 4 desolder power port and clean area then reverse order.
Donnie
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 51
Ao todo: 7,181
